The improved quality of "modern" KD lumber
I live in the midst of the world's production of hardwood lumber, with numerous 25,0000 to 125,000 bdft per day capacity mills is the area. The following is a discussion of what I have seen in the past 40 years of hardwood lumber production.
Years ago mills and kilns were smaller and less sophisticated. Many years ago I provided help at a 30,000 bdft capacity kiln where the operator had a middle school education and couldn't do simple math calculations to calculate a kiln schedule and moisture content. Now days 1,000,000 bd ft of kiln capacity is managed by someone with a forestry degree and the kiln is under computer control.
Back then lumber was sawed, often on small relatively crude mills, put up on sticks, set out in the sun for XX days to air dry as mother nature wished and then put in the kiln to further dry. The stacks going into the kiln would vary in initial moisture content, some lumber would be miscut and might be 1/4" thicker than average, air circulation in the kiln might not be optimumly designed, stacking in the kiln ( a critical factor in air circulation) was under the control of a minimum wage fork lift operator. The product going in was variable and the drying conditions were variable. Some lumber dried too fast and the result was drying defects and stress. Many small kilns had no provision for post drying steaming and conditioning to relieve stress and uniform the product.
The result was lumber discolored from the outside air drying, and a product were at best some boards suffered the ill effects of improper drying- case hardening, honey comb and splits . Occasionally, the whole charge would be screwed up. I believe that much of the folklore of KD lumber traces to lumber produced under these historical conditions.
Modern lumber is produced under conditions I have described in the Articles Section on hardwood lumber production. The modern lumber is not discolored from weathering, it is end trimmed, and dried under carefully controlled conditions to yield a uniform stress free product. (Conditions at Boutique facilities may vary)
That said, if you buy enough lumber you may encounter the result of some screw up in manufacture or grading. Don't claim this exception is the rule.
