Desk- dovetailing the legs to rails
The dovetails involved in holding a case frame or table with a drawer together are less fussy than drawer dovetails because most the result is usually hidden after assembly. So, the next step after mark-out is to consider what will be hidden and use this fact to advantage in preparation. Also, consider what part of the dovetail will be providing strength, or not, so that these mating surfaces can be prepared precisely, or not. In the case of this leg joined to a drawer divider(rail) the only part of the joint that will show is the front mating line. The only surfaces that provides mechanical strength are the edges of the dovetail and not the length or depth for these joints are end grain joints.
PIC1
After sawing the lines that define the width of the dovetail I free-hand route out most of the waste. I use a ¼” solid carbide bit. I find that they are sharper than the bits that have the carbide welded on, and they are different carbide that stays sharp longer. Good light enables routing to just kiss the boundaries to be removed.
PIC 2
There is a trick to the free-hand routing with precise control. It must be done in arcs, never burying much more than 1/8 the bit diameter in the wood. The router motion is clockwise along the arc, right to left pivoting the router about the arc. This technique provides the control that will enable the waste to be removed right up to the line. In contrast to some that route, I route with the flat grain against the router base. This method precisely defines the length of the dovetail socket. In a drawer it is this distance that shows, so an accurate depth here results in a pretty joint on a drawer.
PIC3
Picture 3 shows the result of routing the waste. Note the waste has been removed essentially to the saw kerfs and base line.
PIC 4
Next, the base line is chiseled. There was a recent discussion on holding a chisel. If anyone can quickly stick the chisel tip into the scribe line whilst holding it by the handle they are a better aim than I . I, and plenty of others, find it more reliable to guide the chisel to the scribe line with the grip shown. A gentle whack of the mallet then separates this waste from the dovetail baseline.
PIC 5
Finally, the remains of the waste are cleared out. There are all manner of techniques for this part. I use a chisel that is a bit wider than the waste to be removed is high and rapidly pare until I reveal the shoulder resulting from the saw kerf. This shoulder has been highlighted in pencil for the picture. It is then a simple matter to use this shoulder to guide removal of the rest of the waste. It takes but seconds. Two chisels may be required, one tall enough to pare the sides and a second narrow enough to clip off the fibers at the bottom and smooth bottom as needed. I have never found a skew chisel to be needed for this task.
PIC 6
If all goes well a good joint is the result.
