Saw diagnosis question
Dave (Arlington, VA)
Hi All -
I have finished retoothing and sharpening the no-name saw I mentioned in a post several weeks ago. This has been a experiment and the saw tooth configuration is a bit non-conventional. This saw now has a 30 degree rake, a 25 degree fleam and a 25 degree pitch.
It cuts fine and leaves a very smooth cuts in red oak, but as I pull the saw back through the kerf it develops a pretty pronounced vibration with the blade swinging back and forth as I pull it back to start the next stroke. I thought that I had read that this was a symptom of an insufficient set. I have tried searching the archives, but I can't find anything.
I didn't want to experiment by adding more set until I had first tapped into the forum's collective experience. Can any one help? Is this a problem with the set, or perhaps some other problem?
Thank you for any advice or insights you might offer.
Regards -
Dave
