New WoodChat!
Veritas honing jig
Veritas honing jig
Veritas honing jig
Tony Wilkins
After trying free hand sharpening on my water stones for a bit I'm wondering if using a jig might be better for my shaky hands. I'm thinking about the veritas because it looks easy to setup. Any feedback on them? I'd consider the cheaper eclipse type but they seem more convoluted to setup - ie more guess work.
TIA, Tony
Re: Veritas honing jig
Tom
Good questions. The first one I got before there was an LV was the Eclipse. I found it easy to set up, but limited in the tools it would apply to. I suppose it was difficult to set the angle, but an angle jig takes care of that.
The LV jig is the best there is, it still has it's limitations, but it is easy to set with the angle jig. I kinda prefer the originals, but the current one is fine also.
One thing you might want to look at is the LV gear for sharpening gouges which is pretty close to freehand. If one sticks with crafts long enough, one will probably come to learn freehand sharpening. If that is the goal, then my preferred use for jigs is to use them to straighten out the results of early attempts at hand sharpening (or for hand removal of chips). One can do all one's re-hones by hand, but when it gets to the resharpen stage, slap on the jigs.
Hi Tony
Reading into your question, the need is as much about ease of holding the guide as in adjusting it.
For range of use, nothing comes close to the LV Mk II guide. It can do both straight and skewed blades. Only one other guide can do this, that being the Sharp Skate (which hones in a side-to-side manner, rather than front-and-back as will all others, the LV included). The only real negative about the LV is that it looks complicated as it has an integral angle setter. However, I will emphasize that this affair would be easier for you to use than the shopmade method that goes with the Eclipse.
The main alternative to the LV is the Eclipse - or the copies available, as the original is no longer available. The advantage of he Eclipse is that it is very cheap. It is also very basic, but that is one of its charms. It does one thing only, this being straight bevels. It is rather good at cambering bevels as well. It requires a shopmade jig to set the blade angle, and this can require a little more dexterity than one imagines.
Of the two guides, there is more meat to hold onto with the LV. You will find this easier to hold. The Eclipse is doable, nonetheless, just less controllable than the LV.
Patrick Gibbons
I have the original Veritas but I haven't used it for quite some while. The Veritas is easy, fast and accurate. As others have stated, it has its limitations but is no different from other honing guides. I would imagine that any honing guide will give you a reference to offset any problems with hand shaking. The Veritas is the best of the lot, IMO.
