New WoodChat!
Saw File Sizes
Saw File Sizes
Saw File Sizes
Dave (Arlington, VA)
Hi All -
Caveat emptor. I found this chart on the internet recently and I don't think I have seen it before in my previous trolling through the ether for woodworking information. If I recall correctly I think it might have been attributed to the Nicholson company (maker of all sorts of files). I cannot vouch for its authenticity, or, really, even its source.
Since there's been some recent discussion here of saw filing and saw filing tools I thought I would share this and it might be of interest to some. It opened my eyes to the various sizes and dimensions of these kinds of files. I don't know if the dimensions on the chart will be legible in the pic or not. I hope so. That is part of what I found interesting. It says, "page 10" at the bottom. Perhaps someone has the original document, and - if there's interest - could post it. It might be easier to read.
Regards -
Dave
Re: Saw File Sizes
Re: Saw File Sizes
Don Stephan
For several years when I was learning saw sharpening, I wondered why so many different "thicknesses." Finally I saw a single sentence that suggested using a file just "thick" enough so that only a narrow band in the middle of each side was not used, to minimize the cost of files used. Also, I think the file teeth extended closer to the edges on narrower files.
Re: Saw File Sizes
Re: Saw File Sizes *LINK*
Peter Evans
Dave I uploaded this some time ago, not sure where the first time. It is from a Wiltshire File co Catalogue from the 1940s, and is consistent with Nicholson from that period.
There is an interesting discussion going on in Woodwork Forum at present
http://www.woodworkforums.com/f152/saw-sharpening-files-101-a-171926/
Re: Saw File Sizes
Re: Saw File Sizes
Derek -
Thanks. I think there may be some variation between different folks on which file sizes to use. I looked at this once and I think the biggest variations, if I recall correctly, are between Leonard Lee in his book on sharpening and some of the American tool companies, including Lie-Nielson.
Dave
Re: Saw File Sizes
Re: Saw File Sizes
Hi Don -
Yes...and the other thing I've seen recommended is you should use the longest file from among those files cross sectional dimensions are the same. I think this was to give yourself the longest possible, smooth stroke. It may be too that this spreads the wear, as it were, on the file over a longer length and this may (?) give you a somewhat longer use before dulling.
Dave
Re: Saw File Sizes
Re: Saw File Sizes
Hi Peter -
Thanks. Yes... this certainly is the chart. Who knows maybe this website is where I found it in the first place. I can't recall. By following your link you can see a better view of the chart and actually read the dimensions of the file cross sections. I couldn't make my pic version do that. Part of what I found interesting were these cross sections where it became clear to me that some files of different types (i.e. regular taper, slim taper and so forth) have the same cross sectional dimensions. That's not an earthshattering observation, of course, but I did find it interesting as I was trying to figure out the differences between "regular taper," "slim taper," and so forth.
Dave
