New WoodChat!
Veritas - Innovation in Tools
Hoosiers with Spring Pole Lathe??
Ron Harper
I am trying to decide whether to build a treadle lathe or a Spring Pole Lathe. My use will for Windsor chair legs and supports and the occasional chisel handle. A spring pole lathe is so much easier to build, i would like to see if I could actually use one.k
Re: Hoosiers with Spring Pole Lathe??
Darrell in Oakville
Darrell in Oakville
Ron,
As you said, a pole lathe is easy to build. So easy that you should just do it and start playing with it. I keep mine up at the summer cottage, fun to mess about with in the shade on those lazy days of august. Check out the APT website (just google "bodgers forum") there is a ton of info there. I've made chair legs, candle stand columns, bowls, and even a pen on a pole lathe. It's a great way to use those old carbon steel turning chisels you can buy so cheaply.
I have tried using several treadle lathes, but they all suffer from inefficiencies. All the moving parts, no matter how carefully constructed, will deplete the power you put into it. The pole lathe is directly applied power, I like it much better than a treadle lathe.
Darrell
who just picked up some thread chasing tools at a yard sale, so I guess it's time to start turning again...
