New WoodChat!
OT - erasing an external hard drive
I just got a new external hard drive because the old one was too small to accept backup files after I upgraded the operating system (etc., etc., etc. - when will computers be like fridges, where you buy it, plug it in, and use it?). The old one works fine, just too small. If I erase the old hard drive using Apple's disk utility, will it actually be erased, nothing on it, so that I can safely donate it to a local thrift store? Or is there some other way to wipe it completely clean?
I know this question is not nearly as interesting as a Barry question, but hope someone can guide me.
Re: OT - erasing an external hard drive
Darren Brewster
Darik's Boot And Nuke (dban.org) is an easy and effective way to handle this, that is well regarded.
IIRC it can't be totally erased
+1 Boot and Nuke
Alex Y
Don't know if he has a version that works on a Mac, though.
wilbur
Disk Utility on OS X has the ability to securely erase free space on a hard disk. What I would do is reformat the disk in Disk Utility, which will effectively mark the entire hard drive as free space, then securely erase the free space.
http://support.apple.com/kb/HT3680?viewlocale=en_US&locale=en_US
Warning: this will take a while. This process involves writing zeroes over the hard drive in its simplest form, which is a lot of zeroes to write.
Thanks, all
Now, all I need is a few more round tuits.
Darren Brewster
This is essentially what DBAN does, except it can do it again and again and again, writing all 0s, than all 1s, to assure there are no ghost images of data left on the drive. It will blank the master boot record and everything. Probably overkill, but it is free, so what the heck? Another good utility to keep in the back of your mind for when you really have to be sure.
Re: Thanks, all
Bruce, a MN Galoot
Piece o'cake, Bill, no round tuits needed. Just plug in the HD, start the process and let it run. You can use the computer at the same time, although it might slow down a bit.
