New WoodChat!
A55 Smoothing Plane
Wooden Router Plane Mk II
I recently posted a wooden router plane designed to use the Veritas blades. The guys on the Aussie forum (Ubeaut) challenged me to add a brass section to support the blade. I thought this a good idea, not just for the bling :) but because it would add a little more solidness to the blade bedding (although Mk I is solid anyway).
I must admit to scratching my head for quite some time before coming up with a very simple addition. Here is the finished router plane ...
Doesn't look any different to before? :) Look carefully at the brass "v" at the rear ...
Under the plane the brass channel is more easily seen ...
... and without the blade ...
Loose and prior epoxying together ...
Here in the insert ...
I am very happy with the way this has turned out. I shall be updating my website pictorial to include the details of this modification: http://www.inthewoodshop.com/ShopMadeTools/BuildingaWoodenRouterPlane.html
Re: Wooden Router Plane Mk II
William Duffield
Ingenious improvement, Derek. But I thought jarrah was harder than brass? :D Did you machine the brass part from solid bar stock, or do you have a source for brass solid angle stock? I can only find solid angle stock in aluminum.
Hi William
Thanks for the kind words.
I found a 12" length of brass angle on eBay (Aus). 1/2" x 1/2" and 1/8" thick.
My machining tools are somewhat too basic (Dremel and files) to even consider working with a solid bar of brass!
