New WoodChat!
Mitered bread board end
Ron Bauman
I'm looking for a book that will best describe the how and why of making a mitered bread board end for a table. A friend asked me to recommend a volume to him and for the life of me I don't have any thing in my collection. He's a novice and so just describing it does get bogged down. And a book he can take home.
TIA
Re: Mitered bread board end
Headley description
Bill Tindall, E.TN.
I had Jeff Headley describe it to me. It is described in his slant top desk CD. In summary the joint is scribed and the waste pared away. Not a task for a beginner.
seems like asking for trouble
Chris Friesen
Given that "good" breadboard ends are designed to allow the panel to move with humidity change, doing mitered ends seems like it's asking for trouble....either the miters will want to open or else the panel will want to crack.
Paul M.
This is a really bad joint (regardless of whether you are a novice or not). A table will move in width with humidity changes and a miter will capture the ends of the boards. Something will have to give, and a mitered breadboard end will fight that movement.
A standard breadboard end allows the table to expand and contract with seasonal movement. I would guide him to stick with that.
If the table is plywood or MDF with a veneer, then go ahead and miter away.
JMHO. I've been bit by not planning on wood movement (I still remember the explosive *crack* of my first mitered chessboard project when it split down the middle), so I always plan for this now.
CStanford
Here you go:
http://maxwells.smugmug.com/photos/swfpopup.mg?AlbumID=27435237&AlbumKey=rSWtPW
good in some aplications
Bill Tindall, E.TN.
A mitered end on a slant top desk lid lends refinement to the lid and it works because the end is only mitered on one end. On a table it could look odd and not work if double mitered, as many have stated.
Re: Or
TomD
I think there was a variant on the framed panel by Nakashima, or the cultures he draws from, where the central element is a solid board with integral stiles, the top and bottom rails are mortised at the corners. It works because there is a crack in the middle of the panel. The crack can be straight, a sorta nordic vibe; or it could be a natural crack which works well with max width table tops; or it could be overlapping. Basically this looks like a top with a breadboard joint, and if you wanted miters, it would work fine, though I don't think it would look all that great in most cases. I kinda avoid mitres as much as possible, but if the design demanded it.
Re: Or
TomD
This is a pic of a Nak variant.
http://i686.photobucket.com/albums/vv225/billandmimi/P528000235.jpg
1) Has some interesting detailing to allow bypass and a tight center joint.
B) :) It could be assembled in minutes with biscuits no nothing except square pieces, yet it is refined.
And; I guess another variant would be a floating spline in the center joint.
Hey, here is a Nak with mitres in the box!
http://coveredwithdust.com/files/2012/09/img_1001-791x1024.jpg
Mark Hennebury
What has been said about potential problems is of course true in most cases, but there are ways of getting around those problems;
This is a door that i made many years ago. It was a modification of a design that i saw for a Japanese temple door.
So:
1.it is made of quarter sawn white oak to minimize seasonal movement.
2. Made of 5 boards, tongue a grooved to allow movement.
3.Center board pinned in place.
4. outside boards, mortises and miters are glued & pinned.
5. the miters are not the full width of the outside boards.
Most of the seasonal movement would be lengthwise between the boards and not be of any significance, while the outside dimension remains pretty consistent.
Additional construction info
Mark Hennebury
I forgot to mention that the boards were assembled with 1/16th space between them, and the gaps kept even by placing a couple of small 1/16th inch thick rubber spacers in the grooves.
As an alternative of course board # 2 and 4 could have been pinned, doweled or mortise and tenoned in place.
The mitre joints were epoxied as this is an exterior door and was to have no finish
