New WoodChat!
THE WOODRAT IS BACK!
Installing the "berries" in line and berry
Bill Tindall, E.TN.
Step one is to make them, in my case 192 of them plus some spares. I drilled a pattern of plugs with the plug cutter then mowed them off in mass on the band saw. I used cherry and holly. While I thought differently, in fact the cherry contrasts less on walnut than the traditional cedar. However it has more luster. Not a clear choice between the two.
So, how does one lay out 192 holes in the line pattern. I created this template.
First I extended the holly lines with a compass and pencil. Then I diddled with the template to create a pleasing dangle of the berries and marked the center of the hole with a awl. Then drill the holes and install the berries.
Re: Installing the "berries" in line and berry
David Barnett
(Message Deleted by Poster)
Re: Nice approach, Bill
Patrick Gibbons
Your cherry will darken more than the cedar. You extended the line to aid in choosing the berry locations. Am I assuming correctly? Does grain orientation of the berries have a significant effect on appearance? A very labor-intensive project. No one will mistake it for a furniture store buy. Will you make any other line and berry pieces after this?
Nice, and a suggestion
I have a trick I use when making multiple plugs that might be of interest. Cut the plugs just as you've shown here, then, before you bandsaw them, stick a piece of duct tape on top of the plugs. When you rip your blank on the bandsaw, the plugs will stick nicely to the tape instead of flipping around the shop.
I don't know what color berries are traditional in a walnut dresser, but it might be interesting to try something a little more colorful or contrasty. Padauk, satinwood? The holly will be the same as your stringing, and the cherry and walnut are going to look pretty similar over time, no? Just wondering aloud here.
Bill Tindall, E.TN.
You extended the line to aid in choosing the berry locations. YES
Does grain orientation of the berries have a significant effect on appearance?.......I used a neat quarter sawed piece of cherry with tiny "flakes" yielding a pattern where the grain direction is not discernible. Otherwise I would have oriented the grain to flow in the direction of the line.
A very labor-intensive project........ The template made this go quickly. I was actually surprised what a short time it took to install all of them. Leveling to the walnut background, that was another story and a LOT of block planing. Chiseling to remove most of the projection did not work out well.
Will you make any other line and berry pieces after this?...yes, two night stands with 3-4 drawers.
why didn't I think of that
Bill Tindall, E.TN.
While most of the berries got captured by the band saw fence I spent a fair amount of time on my knees hunting the remainder. It will be tape next time.
As far as other woods, Steve Latta offered some good advice. He suggested subduing the contrast of holly and walnut with the finish. Depends on the look one wants. "In your face modern" might benefit from some foreign wood inlay but its not for me on this piece.
Simple minded approach
I've never done 192 plugs, and maybe I'd adopt the bandsaw approach if I did. I always just stick a small screwdriver down beside the plug and lever it against the plug, then repeat on the other side. One thing I like about this is that the broken grain gives me a very clear picture of what direction the grain's running, so I can match it to the wood into which I'm installing the plug.
