Re: fix for tight handle on eggbeater drill?
Lars Parrington
I just finished restoring two millers falls hand drills. I took the crank handles off of each, filing off the rivets to do so. One of the handles was siezed-up beforehand -- the pin had rusted, swelling in diameter in the process. I suspect that is was caused it to sieze, although the handle was also very tight longitudinally, so that could have played a role too. I don't think I would have gotten it signifcantly loosened without completely disassembling it.
If you file off the peened part of the handle's pin, there may not be enough material to re-peen when you go to reassemble. One option would be to drill and tap the end of the pin for a screw instead, making future repairs easier. Alternatively, you could cut the shoulder of the pin back a bit, so that more pin material sticks through the metal bar. This shortens the useable length of the pin, further aggravating your problem of the longitudinally tight handle. However, a good workaround is to deepen the counterbore in the handle, so the pin head sits further down into it.
I chose the second option for my tight handle. The counterbore wasn't deep enough to begin with and was cut off center, so I was able to clean that up at teh same time. re-peening the handle pins was easy enough -- used the end grain of an old axe handle as an anvil to supported the head of the pin, while hitting the other end of the pin (lots and lots of times, but not too hard) with a regular 16oz hammer.
