New WoodChat!
Finishing on 1st sign of spring
Bill Tindall, E.TN.
It is in the 70's today and I took advantage of it to put the first coat of varnish on. If it is warm like today I can get it dust free in less than an hour and then move indoors to cure. Not sure why I have been using varnish. I do like the luster but I think I can get to the same place with lacquer and get there quicker. I would already be done if I was using lacquer.
It is curious how the two drawers turned out of the sun's reflection appear almost black. They are not in reality.
Re: Finishing on 1st sign of spring
Bruce, a MN Galoot
Those look really good, Bill! I don't think I ever had an idea of the scale of that dresser. How wide are the drawers?
And as for your first sign of spring, we have winter storm warnings out for tomorrow, up to a foot of new snow, just when the last of the old snow melted yesterday.
jack curtis
It's all relative, even for digital photography; so if your exposure is set to optimize the brighter fronts, the dimmer looking will look dimmer. There are ways to adjust for this.
TomD
Those look dangerously close to the road. An old design, on the driveway, that would be the local signal for removal. The fact that you freshened them up with varnish, just shows you care.
William Duffield
Naw, what you're looking at is the end of Bill's driveway. From there, it's about 1100 feet out to the public road.
size
Bill Tindall, E.TN.
The dresser is about 3' square.
Patrick Gibbons
Bill, the drawers look beautiful. I have appreciated the reports you have made along the way. I enjoy seeing the project all the way through. I use a tung oil varnish; probably not what you're talking about. I rub it on and wipe off the residue. Doesn't take much time but have to let the layers cure. What would an original have used? Linseed oil? Shellac? Can't wait to see your finished product.
Don't know
Bill Tindall, E.TN.
I don't know much about historical finishes, what was used when and in what region. The pieces in the museum had not been recently refinished because I could see a shadow from previous brass, replaced some time ago. The finish looked like shellac or varnish, as it was a finish that had some build. But it might have been put on in 1880, 150 years after the original finish.
Re: Don't know
Patrick Gibbons
I guess a better question would be if a shiny or a dull finish is more desirable?
shine vs dull
Bill Tindall, E.TN.
A shiny finish will make figured grain more prominent like on the figured panels. For the case at hand a duller finish might be preferred for the line and berry but I have not decided to rub out the varnish yet. It is always something that can be done later at any time. Varnish dulls up with time anyway so I may just leave it for a bit and see where it goes. The other Chester Co piece I built some years ago has aged to a pleasant luster.
