New WoodChat!
Most popular LV router plane blade sizes
Jay St. Peter
Historically, I've been the kind of guy that would always buy the complete set. But, I've been doing some serious deep cleaning of the shop lately and realizing I have a lot of stuff like that I just never use.
I'm planning on building one of the Derek Cohen router planes using the LV blades. But I've never used a router plane. So, I'm wondering what the most useful blades/sizes are.
My thoughts are to get the 1/2" spear point blade and a smaller blade (3/16 maybe). Since I mix hand/power tools, I'm thinking uses are cleaning dados and smaller work that is quicker to just do by hand than set up power tools (i.e. hinge mortises). What are your favorites?
Re: Most popular LV router plane blade sizes
Bill Tindall, E.TN.
nothing beats a small modern trim router with LD lighting and a 1/4" bit for cleaning our hinge mortises. With a bit of practice and good light one can route right up to the scribe line leaving just a sliver to be removed by chisel. I use a router plane for sizing the depth of housed mortises used for drawer dividers. I only have a 1/4" bit and it works for how I use it.
I recently bought the LV router plane. Its handy depth adjustment may lead me to use this tool more. I found the Stanley sufficiently inconvenient that I reached for the router with 1/4" bit more often.
Patrick Gibbons
I have the Stanley and its smaller brother. I mostly use the spear point blade in the larger router but it also came with the 1/4" & 1/2" bits. The small router (271) comes with one 1/4" bit. I find I use the 271 for small box hinges and other smaller work. I really like having both. I'd love to get the Veritas versions but can't really fault what I already own. If I do buy them one day I'll probably wonder why I waited so long. It sounds goods to have a range of sizes but I think it's unnecessary. If you need a consistent depth on something less than 1/4", then buy a smaller bit. I would presume a bit wider than 1/2" would be harder to push through the wood and end up lessening your precision. At any rate, the 1/2" bit will get a recess done quickly no matter the size. (Within reason of course). Make your router and buy just one bit. Use it and I'm sure you'll know soon enough if you need to go back to the store to buy another size.
Hi Jay
I would aim for a 1/4" and 1/2" blades, the 1/2" being the square one. The pointed blade is a finishing blade, and will get much less use.
LV sell blades from 1/8" up. They will all get use at some stage - there is always a need when you don't have one! However, a 1/4" and a 1/2" should see you through most work.
One of the reasons for the size I have built is that it has the same registration across the width as the Large Vertas/LV router plane. I find the small router planes too narrow for hinge mortices. They are OK for fine detail work .. but then so is the large router plane (actually this is still better as the registration and the mass is there).
Jack Guzman from Maine
I have all the blades that LV provides,including the mini sizes. Over several years of steady use the one I use most is the 1/2" square edge. The 1/4" is necessary for dados too narrow for the other but the 1/2" is the one vital blade for leveling recesses of all sorts. The sides of the half being square and sharp help define edges in a way that the spear point can't.I would say the spear point would be nice for carving where the appearance of the hollowed surface was important.---Jack
correction
Bill Tindall, E.TN.
It is the 1/2" that I have and I have not so far had any need for another size, but I don't so small hinges with it.
My use of the pointed blade
Patrick Gibbons
I use to never use the pointed blade. But now I find I use it most. When sharpened, it cuts with less resistance and does leave a smoother surface. It's shaped like a plow blade used in farming. I cut a dado with a saw for defining the walls, followed by the chisel to hog out most of the waste and finish up with the plow-shaped blade in the router. Throughout the process I use a knife to keep the walls sharp. I find the point is good for getting into corners also. Most people tend to ignore the plow blade but if it's sharp it really is a sweet user.
Jay St. Peter
One of the things I like about making my own plane body is that I can make the opening any size I'd like. Multiple bodies with different opening sizes even.
Thanks Guys
Jay St. Peter
My first thought was to get the regular 1/2 and 1/4. Maybe I over thought it afterward. I'll start with those. If I find that I use it enough and would benefit from others I'll just add them to future orders until I have the set ;)
Jay
