router plane question
Jerry Gibbs
Looking at a Miller Falls No 77 router plane on ebay. The picture shows one blade, looks like 1/4". If I buy this, will I need/use other blades and can they be reasonably purchased or made? Thanks. Jerry
Jerry Gibbs
Re: router plane question
William Duffield, in Winter Haven
From here, it appears to be identical to the Stanley #71-1/2. If so, the Veritas blades will fit, but you have to turn the knob over. Whether or not you need other blades no one can answer but you. Also, old Stanley blades are available on the used tool market.
TomD
They are easily made, and the bits can be HTd with a simple propane torch. LV also made chip blades that screwed to a stub, so you could theoretically make a stub that would fit any plane, and you could them attach the LV cutters.
