New WoodChat!
Stanley #75 ........again
scott grandstaff
scott grandstaff
The Stanley 75. Hardly anyone else loves it, but I do.
We were talking about it on the Porch. I had dropped the last one I had. So Bruce Z sent me one!
I tuned and sharpened it up and its a great little tool. Got to love kindness like that.
I replace the missing lever cap screw and tuned and sharpened it up. Ready for action.
Meanwhile as all this was happening I got a note from Bill Houghton. He had made a little palm rest for one of his some years back. And even though I didn't have a lot of trouble holding and using mine, what could be wrong with a little cushion for the pushin?
Here was the original archive post, minus the pictures
http://www.woodcentral.com/woodworking/forum/archives_handtools.pl/bid/3104/page/1/md/read/id/45845/sbj/improving-the-no-75-to-mediocre-rambling/
So I basically copied his concept. Here's mine. a little Bolivian rosewood scrap I grabbed from the box, and fit. And I like it!
Thanx Bill
yours Scott
Stanley relieves the body of this plane narrower than its sole. I am not sure why besides less machining. So I made mine as wide as the sole so its square laying flat. Gave me a bit more width. I will post that pic in a reply immidiately following this since I can't figure out how to post 2 pix in the same message.... heh
Re: Stanley #75 ........again
Re: second pic
TomD
Looks comfy!
Neat!
Denis Chenard in Ottawa
How to you attach the palm rest to the plane? I have a MF #4 that's gathering dust somewhere, maybe I'd use it more with this improvement...
DC
scott grandstaff
Re: Neat!
scott grandstaff
DC
There is just enough room for 2 round head, #6, brass screws, side by side, across the "flats".
I used 5 minute epoxy to hold the fitted-to-the-body-until-no-light-showed palm rest, in place.
Then drilled up through the cast iron.
First a clearance bit to just clear the screw shanks, then pilot holes for the screws.
yours Scott
Re: Neat!
Scott is always more comprehensive and thorough in his work than I'll ever be. I used one wood screw in my version, and steel at that. Like Scott's, the screw comes in from below.
Silk purse from a sow's ear
Patrick Gibbons
I know this plane is much maligned. I've sold my bull nose and my 92 because I've never seemed to need a bull nose. What do you use yours for?
i like the #75
Lars Parrington
neat!
i actually quite like my #75 and use it often. perhaps i'll make up a palm rest next time i use it. as long at it is set for a fine cut it is a pleasure to use. a heavy cut is no fun, probably due to plane's lack of mass, length, and chip clearing. i mostly use it for tight spots and stopped cuts, but also sometimes as a shoulder plane (my only other shoulder/rabbet plane -- stanley 90-something -- needs a tune-up, and it currently barely useable).
i flattened the sole of my #75, bringing the nose into the same geometrical plane as the rest of the sole (which is against what patrick leach recommends). perhaps this is the difference that makes the plane work for me.
Mine is a paint plane
I've noticed painters seem to like them. I (blush) own a couple of other bull nose planes that are better at planing wood, but the 75 comes out when I'm doing paint prep on the house; I can abuse it by planing off paint lumps and so on without worrying about damaging it.
As to bull noses in general, I've been doing more architectural than shop work for some years now, and a bullnose can be very helpful when fitting trim, at least for me.
Adjusting the nose on the No. 75
I've seen more than one person refer to correcting the gap at the nose of the 75, apparently a factory feature. In fact, most everyone who uses it much seems to do this.
I was lucky; my machinist uncle offered to do it for me, which he did by filing the top of the body where the top casting (which curls over to form the nose) rests. As he pointed out upon returning it to me, there's less metal to remove that way.
Re: Adjusting the nose on the No. 75
Bruce, a MN Galoot
Bill, is the toe flush with the rest of the plane bottom? I have access to a mill at work, and that would be an easy fix.
It is now, thanks to my uncle...
...one of the many, many shop gifts from him that trigger fond memories of him every time I use one of his tools, or one that he fixed for me.
Ron Harper
Scott,
What is your primary use for this cool lookin little plane?
scott grandstaff
scott grandstaff
Taking the body of the plane down, to let the toe piece sit flush?
Is a piece of cake.
Mainly just scrape off the japanning. That gets you 90% of the way there, with just that.
A further light touch of a sharp file and you're done.
In use, the tool is a little piece of magic.
Drawer sicking? Window plane a little too big?
Door or panel or frame member just a bit off? Straight part or rabbit?
Its not a tool I use long and hard. I use it when the chips are down and when tuned and very sharp? It makes magic.
I have heard the story many times, that the men who built Main street in Disneyland carried a 75 as a badge of honor and mastery.
Not what you use for layout or construction,
its for extracting your butt from a too tight spot.
yours Scott
Re: Mine is a paint plane
Patrick Gibbons
Thanks for the info. Stanley made this gem for a long time which made me believe it was popular. Just didn't know why. I still worry I was premature at selling my Veritas bull nose but I haven't missed it yet.
Re: second pic
Tony Zaffuto
Great Idea and execution Scott! I don't have a Stanley #75, but I do have the MF equivalent and, as Phineas says to Ferb, "I know what I'm going to do this weekend"!
