On making string trough cutters
Bill Tindall, E.TN.
This post is a response to a question below but the answer may be of more general interest to merit a new posting. Part of the excellent class with Steve Latta on doing stringing included cutter making. What we learned:
The blanks for the LN string trough cutting tools are sheared from card scraper stock. One can readily find this stock, for example LV, and shear or saw it into strips. A fine tooth hack saw will saw the stock if it is secured between two blocks of wood to stiffen it. Or it can be cut with a Dremel and cut off wheel using a strip of wood clamped to the stock as a guide.
Holes can be bored with a Dremel and an abrasive tool , or punched if you have a punch. The punch available from Harbor freight will just do the job on 0.032" stock. The teeth can be filed with a small file suitable for filing a dovetail saw. The stock can be shaped with a Dremel and abrasive wheel.
Another simple way to make cutters is to shear strips of 3/4" 10 tpi band saw blade containing 2-4 teeth. Stone out the set in the teeth.
