Bridge pin reamer
Pat Mulligan
Anybody know where I can find a 3 degree reamer for guitar bridge pins that doesn't cost a fortune? I just purchased one from Grizzly and it's no good.Another bargain hunt gone bad. Thanks Pat
Bridge pin reamer
Pat Mulligan
Re: Bridge pin reamer
William Duffield
Stew-Mac (stewmac.com) or LMI (lmii.com)
http://www.stewmac.com/shop/Tools/Reamers/Bridge_Pin_Hole_Reamer.html?actn=100101&xst=3&xsr=466
At least, I don't consider two thirds of a Franklin a fortune for a precision tool of hardened tool steel.
TomD
This one is cheaper:
1) http://www.lmii.com/CartTwo/thirdproducts.asp?NameProdHeader=Bridge+Pin+Hole+Reamers
I think it would be relatively easy to make your own. The reamers made out saw blades work really really well. A small Eclipse hack saw blade could easily be ground into a reamer, and they are easy to tune.
2) Another option is the many variations in pin free bridges. Pin Bridges are obviously a workable design, but other than being traditional, I don't see anything about them that is superior to the pinless designs. If you are making a guitar for yourself I would seriously consider a pinless. Commercially, even though they are a superior design, there is the whole selling a house with a pool thing, so it would probably be worth going for the pins, just to avoid a sale hanging up over an educational issue. You could make the 45 bucks back on the first guitar. There are also fancy pins that may suggest an upcharge.
http://www.elliottguitars.com/bridges1.html
http://www.doolinguitars.com/pinless.html#
http://www.baranikguitars.com/restring.htm
I think one of the cleanest systems is holes through the bridge to the inside, and the strings simply thread through a trap door, which is useful for a lot of other stuff. Trap doors are nearly essential, particularly for new builders, but questionable for commercial guitars. They ought to be ideal, but you end up responsible for whatever happens when the client decides to mess around in there. None of which is likely good.
3) Is there any way you can sharpen the Grizzly hone, did you call them about it. As you know, their pres is the reason they sell guitar stuff at all. I am surprised they are selling crap on his watch. I mean the 10" sander, I can see how that is an economy option (though people say it works OK). But to make something like a reamer, and for it to just not work, would just make them look like idiots.
