We value your privacy.
Ever had a terrific idea that did not look quite so good when executed? Like Don Quixote, I rescued these vise screws and wanted to use the on my small auxiliary bench. I now do about everything with hand tools and i use my vise a lot.
Way too fussy!
I have the nuts loose at Stephen prescribed. Could i cut the front chop in two, put ways in the bottom edge and extend them thru the apron to help with alignment. Use the leftmost half as my vise and use the other half in tandem if I need to hold something wide vertically?
What's the fussy part? Having to spin both screws to do simple stuff? Or the nuts floating loose in back? How much advance do you get from one screw turn? Would it help to shorten the handles or get the nuts to hold still?
I intend to shorten the handles some, but they really aren't the problem. I get almost half an inch a turn. The issue is keeping the screws in sync so that the chop is parallel to the apron. And keeping the face of the chop parallel to the apron. I really do realize that I cannot use these and get quick release vise performance. I'd like to get a little closer.
I would suggest you put a way or follower under each of the hand screws through the loose chop and the bench apron. A couple of rectangular ways will keep the loose chop in better alignment and make it easier to use.
The way is fixed to the loose chop and through a mortise on the bench front apron.
Hi Ron
I have a Moxon vise, which is essentially the same deal as you have.
The trick is to open the vise, then place the work piece into it at one side, roughly close of that side, then only use the other handle for adjustments. In other words, you are not attempting to start from scratch each time you fit a board of the same thickness - you fit one side only, then open and close on the other side.
A refinement to Derek's good advise, wich insures it always works, with the least fine adjustment:
Decide which end of the vise you want to work at. This depends on which hand you like to use to operate the vise and where on your bench you have put the tools you are going to work with. (For purposes of this explanation, I will choose the left end, but you can reverse everything if you like to work near the right end, operate the vise with your right hand, position your stock with your left hand, and pick up your tools with your left hand.)
1 - Position your stock near the left screw and tighten the left screw until the jaw almost touches the stock.
2 - Slide the stock all the way to the right screw and tighten the right screw until it just touches the stock. Do not snug it down.
3 - Slide the stock all the way to the left screw and snug the left screw down.
When you remove the stock from the vise, only loosen the left screw one turn.
This method saves time and effort because when working with multiple pieces of stock of the same thickness on which you will perform the same operation (e.g., drawer sides or stiles and rails), you don't need to adjust the right end of the vise, just position subsequent stock at the left end and tighten the left screw (step 3). The longer your vise jaw the better this works, unless you make the jaw so long or so thin that it flexes when tightening the screws.
A similar strategy works for hand screws, but I recommend always using your stronger hand with the rear screw to apply maximum pressure
Our craft is full of little mysterious things that are not intuitive to most of us, but become delightfully simple when some good soul explains it to us. I had never before use a wooden screw vise, let alone in a twin screw configuration, and was befuddled.
William took a few minutes and taught me a lesson. Wow!. It works just like he said it would. I really believe that this eliminates my frustrations, and my vise will stay just like it is.
William, thank you once gain for being so willing to share what you have learned along the road. I owe you a big drink.
Operating a twin screw vise, with either wood or metal threads, can be really frustrating if you don't know an effective technique. I was also flabbergasted until someone explained to me how to do it.
Yes, i used the suggestions that Derek and William posted above. Indeed they were helpful. This morning I went ahead and put in ways as Stephen suggested. AAAAAAHHH!
