New WoodChat!
hockey mask finish?
hockey mask finish?
hockey mask finish?
Jerry Gibbs
curious what finish is applied over the elaborate paint scenes on hockey goalie masks. Sure takes a lot of punishment.
Re: hockey mask finish?
TomD
From googling around it sounds like a 2 pack isocyanate clear coat auto paint. There are some spray can versions, and while they work they are not as good as mixing and spraying. Any time you spray this stuff there is the possibility of really bad things happening. As I understand it there is no way to filter the harmful components with the usual cartridge filters. Aircraft guys have killed themselves using this stuff because they sprayed it in contained spaces and even the small projects are a little big. I have used a lot of this stuff on boats but I use it with a roller and a tip off brush, which is reasonably safe even when the project is like 200 square feet at a time or more. My pal used to spray-paint two pack and he is blasé about the safety issues. He just uses some simple system where he gets positive pressure from the same compressor that feeds the spray gun. I didn't like the sound of that because generally those compressors are not considered human air supplies, but then in the kind of deal you would be doing you would only spray a few seconds, and so the risk of high den sity of iso is greater than a little polution in the positive air, I would have thought. It is all doable just take some reasonable precautions with the Iso.
Re: …really bad things happening *LINKS*
William Duffield
There are many different isocyanates, all with deleterious effects on your health.
http://www.osha.gov/SLTC/isocyanates/index.html
Perhaps, the most dangerous effect is occupational asthma, which can be fatal. Worse, since the isocyanates are sensitizers, you may get away with using it for a while with less than ideal protection, and then develop an acute sensitivity, and drop dead the next time you use it.
http://www.osha.gov/SLTC/occupationalasthma/index.html
The two links provide recommended protection.
Re: Mouse stuff...
TomD
One of the giants of my woodworking life Jan Gougeon, near the beginning of his retirement life died of some lung disease seemingly because while renovating his home he was exposed to mouse... excreta.
Fun things one can do with plywood:
Re: Mouse stuff...
William Duffield
That would probably have been Four Corners disease, a hantavirus.
http://www.cdc.gov/hantavirus/hps/history.html
I read about Jan's passing over the bar back at the Winter Solstice, a significant loss to the world of boatbuilding.
http://www.westsystem.com/ss/jan-c-gougeon/
http://www.idniyra.org/articles/gougeon.htm
