New WoodChat!
Anyone ever done this?
Edward in Vancouver
I needeed 1/4" dowels and saw some oak scraps that would do nicely. I don't have a "real" dowel plate, just a hunk of 1/4" thick steel scrap with a lot of random holes in in it. It was never fun pounding stock through it, so I took a different route.
I pulled out a cheap tap and die set, stuck one end of the square oak scrap into my pencil sharpener, and chucked the other end it into my drill, and drilled it through the 3/8" die. Easy-peasy. Then I ran it through the 5/16" die. After that I pounded it once through my 1/4" hole in the plate. Grand total of 2 minutes.
It's too simple, someone must have thought of this before..........
Re: Anyone ever done this?
Philip Duffy
U bet!
Patrick Gibbons
To understand, you're putting threads on it and reducing in size with each level. Sounds good. I have a dowel plate and it's not an easy operation. It works but I seem to have to fiddle with it more than I would like.
TomD
Keeping in mind that a die set is just 4 holes in a cluster, you could make something specific to your use with some scrap and a drill bit.
Edward in Vancouver
I guess I could, I just had a garage sale tap & die kit handy, got it for the 1/4"-20 only. In any case it sure beats (!) pounding dowels through a plate multiple times.
TomD
Oh yeah, that makes great sense. I was just musing that one could pretty easily make a sized one with a few holes, possibly two holes would do it. But sure, your idea is great. I couldn't get by without my tap set, and if you have one, you could do what you have done. I was wondering whether the surface was clean, or presumably threaded? And if threaded, did you then pass that through a hole. Presumably threads would be easily broken off...
Edward in Vancouver
Oh, there are threads, very shallow and weak, but they shave off nicely. I don't think it's "my idea", I'm sure someone must have used this technique before.
I have used the "Threads" on this kind of dowel to my advantage. Before Christmas I made a batch of pencil boxes as presents--the kind where the top tray swings open to reveal the bottom tray. This pivots on a dowel. Normally this dowel was to be glued in the bottom half. I just chucked a length of "all-thread" dowel in my drill, and drilled it through the top tray hole and into the bottom tray holes. The top pivots nicely and it won't separate. The threaded dowel was teak, and the box was made of soft maple, good compression fit.
TomD
Great idea, though with all of that I might have been tempted to use delrin rod for the strength. But there I go, I hate it when people underestimate wood...
