New WoodChat!
THE WOODRAT IS BACK!
Jigs for plowing?
Jigs for plowing?
Jigs for plowing?
Ron Harper
Anybody have a clever idea for holding small pieces while grooving with a plow plane?
Re: Jigs for plowing?
One traditional method - slower than David Barnett's - for working small pieces is a sticking board - board the correct length with a groove in it sized to hold the piece being worked. You'd have to think about how to deal with the fence - depending on the size of the stock, you might be able to align the fence with the edge of the sticking board, not the stock.
Pictures of the stock you're working might help, if you've got a digital camera.
Jack Guzman from Maine
Another thought . If you can find some way to hold your plough plane in a vise you could plough the groove by running the piece through the plane.
David-I keep a hot melt gun handy. When repairing furniture the glue is an ideal way to glue back together hopelessly broken pieces to get a shape to follow for making replacement parts.---Jack
How small, Ron?
Wiley Horne--So. Calif.
Is the problem getting thin stuff like frame sticks up in the air, so that the plough fence will clear the bench? Or is it narrow stuff that bends between dogs?--in this case, rabbet a length of board that you can catch between dogs, where the rabbet is just narrower than the thing you're ploughing. And put a screw head at the far end as a stop.
Or are these really short items that can't be caught between dogs? Sometimes these lend themselves to sawing.
Wiley
Re: How small, Ron?
Ron Harper
2 in wide by 17 long and 11/16 th thick for a recent project. The sticking board idea is an obvious one. That handles stability in the direction of the cut. How about laterally?
Since posting my query, i have seen a video where Paul Sellers fits the piece lengthwise in an aluminum bar clamp then puts the bar clamp in the face vice parallel to the front of the bench and Robert is married to your Dad's sister.
Neat quick solution. I tried it and of course it works beautifully.
Thanks for the suggestions.
