New WoodChat!
Somewhat Off Topic: V Belts
Phil
OK, looking for a replacement belt for a treadmill. The belt has the following printed on it: Jason (Made in France) 230J 1-004. When I had the unit apart, I did not think to count the ribs on the belt. Anyone have an idea how I can cross reference to an obtainable part? Side note: treadmill is dripping with silicone, which is lubricant used for walking/running belt. My paranoia about silicone and wood finishing has me wondering what to clean the tools with to remove the silicone contamination prior to putting them back into service in the WW shop (open end wrenches/sockets, etc): I used mineral spirits and then WD40: not sure how much silicone could survive after that treatment.
Re: Somewhat Off Topic: V Belts
john sayles
short of a cross-reference, you have two choices: contact MFR of treadmill for replacement or specs OR take measurements width, no of ribs, depth of ribs, length of belt THEN match to replacement belt with same specs from different maker.
I have always used Simple Green to wipe out silicone.
Lars Parrington
i believe 230J is the size of belt, although i would have expected a number after the J to specify the number of ribs.
for example, i recently purchased a 340J8 belt for a treadmill i modified. the belt is 34" long and has 8 ribs.
Phil
OK, thanks for the key to the secret code. Replacement belts do appear to be available, and the missing digit/character is apparently the number of ribs. Mystery solved.
