Sawn veneer; order of assembly?
Wiley Horne--So. Calif.
Hi All,
Am circling around the glue-up of a desktop, trying to think how to proceed with the top veneers, which are sawn satinwood approx. 1/8" thick (they'll finish about 3/32"). Here is a photo of the loose pieces I'm working with: The center field is quartered satinwood; the crossbanding is ribbonstripe satinwood, 2" wide:
http://www.flickr.com/photos/78661951@N07/8493267960/in/set-72157632172323442
The crossband will be mitered at the corners. There will be a string (white, black, or black/white--not sure which yet) separating the center field from the cross banding, and another string outboard of the cross banding--this latter string will be rabbeted into the satinwood lip that will be the edge of the top. I expect the finish will be oil followed by X coats of blond shellac; cut back the shellac to satin, and wax.
How to proceed? Am sure there is a standard way, but I don't know what it is. Here are the options I see:
Option 1, Center first: Glue the center field first, making all decisions about string and string widths up front; leave enough margin so that the top can be trimmed back to the cross banding after it is applied (so the crossbanding itself doesn't have to be trimmed back to take up fitting error); then plane off glue, apply lip, level everything, and apply finish as final step.
Option 2, Crossband first: Glue the crossbanding first, leaving stringing decisions open. Then fit the center field into the open middle, getting it to within 1/32" of a fit all around; plane off glue, level, and add a first coat of finish; now make stringing decisions, having seen the color and grain of the wood in full-size; cut in the interior stringing and plane it level; add lip to outside; add finish as final step. (The outside string will be rabbeted into the lip.)
Both options have advantages and disadvantages. In principle, I like Option 2 because I can see the final top before making the stringing decision. However, cutting the stringing into the finished top will not be real easy because the channel has to be cut 2" into the interior of the top (which is kind of a long throw for me) and slip-ups can be fatal at that point. Option 1 is easiest and most straightforward, but requires all decisions to be made up front--though I suppose if I guess wrong on the stringing, I could always dig it out and be no worse off than if I had gone Option 2 in the first place.
Any and all thoughts welcome!
Wiley
