New WoodChat!
200+ woodworking book reviews
String Theory
String Theory
String Theory
Bill Tindall, E.TN.
No not that string theory, the federal Leg and Line and Berry kind.......
Picture 1 shows most of the pattern completed. The question is in what order are the troughs for these 14 pieces of string scratched. The following discussion applies to stringing a Federal leg as well as Line and Berry.
What is not done is to scratch the whole pattern and then start filling it. Among the problems that will develop will be small pieces of walnut vanishing from the field where troughs intersect.
Intersections can be done by two routes. The points of the diamond, the intersections of the circles with the diamond and the points of the tulip present these challenges.
A line can be installed and the intersecting line then butted to it. The difficulties of pulling off perfect butt joints are daunting, but it can be done, tediously.
Pictures 2 and 3 show an alternative approach. The first line is laid down and the trough for the second line is cut into the first line's space. While this insures a perfect "joint" it demands perfect layout of the compass points.
These lines are 0.030" thick. If the compass point is off by 0.010" then the intersection line will be too fat (0.040"), or miss altogether. One sees plenty of these alignment errors on antique pieces, including the signature Chester County chest of drawers at Winterthur.
It turns out that a divider and a square can be used to layout the pattern as I previously described. With care the compass points can be located with sufficient precision that the intersections can be made nearly perfect.......providing the board doesn't move. I have discovered that at the thousandths of an inch precision the compass points do move about from day to day as humidity changes. Hence, once a pattern is laid out and started it is best to finish it.
Re: String Theory
Re: String Theory
Bill Houghton
Your observations as you've done this work have been terrific, Bill.
