The frugal stringing sizer
Bill Tindall, E.TN.
We made this sizer in class. The cutter is a piece of Lee Valley card stock sheared into strips and screw holes punched in it (card stock will accommodate hole punching). It is sharpened at about 45 degree bevel on end and a gentle hook rolled on the edge.
I have added two modifications. First I drove the blade down into the wood so that the bottom of the blade was below the bottom of the saw kerf where the string goes. (Driving it down makes a channel for the blade to slide in. Second, I added a hole at the end of the blade. With the blade snug, a marking point is stuck in here and the blade precisely pried closed to get the desired thickness of cut. (It is fiddly getting the blade adjusted with the screws loose.)
And, to justify the price of that, a vernier scale…
