New WoodChat!
more on drawer sides- lumber choice
Bill Tindall, E.TN.
This may not be something to worry about unless you expect your furniture to survive for 300 years..........
I had occasion to inspect a Chester Co. chest of drawers (ca. 1720) in the Mack Headley and Sons shop, Winchester VA. It had a curious combination of original drawers (identical dovetailing details) where the 1/2" sides were either quartered oak or poplar. The quartered oak had worn substantial grooves into the runners and dividers. The poplar had assaulted these parts much less so.
Re: more on drawer sides- lumber choice
CStanford
Any information on what was loaded in the *respective* drawers?
Bill Tindall, E.TN.
Further analysis revealed that over the past 300 years the 17 documented owners of this piece ALL kept their coin collections in the oak drawer and socks in the identically sized adjacent drawer.
Soooo....
John in NM
Guess it's a good thing I keep my lead brick collection in the kitchen drawers? :D :D :D
craigd
You laugh ...
craigd
25 pounds
Not all all surprising
Ron Harper
I guess I always thought that if you use oak drawer sides, any wood that they bear on need to be at least that hard.
Actually...
John in NM
I'm not joking, I really do have a lot of lead lying around in various forms. I don't keep it in the kitchen though :D
Its an amazingly useful metal.
David Barnett
(Message Deleted by Poster)
Tapping out Japanese plane irons?
Wiley Horne--So. Calif.
I've often thought a lump of lead (like the ones we used to carry in the plumbing supply warehouse I worked in as a high-school kid) would be a good 'anvil' for tapping out Japanese plane blades. Because it could be molded exactly to the ura of the blade and provide full-width support.
But then, maybe it wouldn't resist the hammer tap well enough to move the hard steel?
Opinions from the tapper-outers out there......?
Wiley
David Barnett
Re: Pure lead doesn't work harden... *LINK*
wilbur
Haven't tried lead, myself. I know too much about lead toxicity in kids to bring it into my house. And I know that the ingestion issues probably don't apply to sheets of lead. But that's one thing I allow myself to be irrational about.
I've tried a piece of end grain white oak fashioned with a convex surface (I think Odate mentions using a wood anvil in his book). I currently use a dolly (a tool used for repairing dents in your car) as an anvil for tapping out, and it works great. I should probably make a base for it.
Using a dolly to tap out a Japanese plane
For a harder alloy...
John in NM
Wheel weights are lead and antimony and are a bit stiffer than pure lead. The alloy is also readily available as ingots on ebay and forums frequented by bullet casters, going rate is about $1/lb. Ingots tend to be small, but might be big enough to try some tapping out. Maybe one of the muffin tin ingots would work best, being round and tapered.
Re: For a harder alloy...
Hi John and all,
Like these:?
http://www.ebay.com/itm/15-POUNDS-WHEEL-WEIGHT-LEAD-INGOTS-BULLET-CAST-BULLET-LEAD-MOLD-LEAD-RELOAD-/181079651917?pt=LH_DefaultDomain_0&hash=item2a2930364d
That's the right shape, all right.
I have a favorite blade that's about to need tapping out. Been putting it off, because it's been a few years since I did the last one. This is my anvil, a mild steel chunk of hexagonal bar stock--use one of the rounded over corners:
http://www.flickr.com/photos/78661951@N07/8476114109/in/set-72157631881424249
I may just put a stick of wood in a vise and use that as a stake to tap against, following Wilbur's suggestion per Odate. One of the keys I find is to relax and let the hammer do the work (like they always say). Nothing feels worse than a pinging hit off the mark.
Good idea about the ingot!
Wiley
My, they've gone up!
John in NM
I generally don't follow the ingot selling, seeing as it's a lot cheaper to buy a bucket of weights from a tire shop :D
$2/lb seems like a lot though.
