New WoodChat!
Help with plow plane please
Ron Harper
Any ideas on how to retro fit a depth stop?
Please and Thank you
Ron
Re: Help with plow plane please
Not sure I can do that
Ron Harper
I have less that 5/8 of stock on the outside of the skate
John Aniano in Central NJ
Hello Ron,
I'm pretty sure this is NOT a plow plane, at least not the fully adjustable variety. It is instead a dedicated grooving tool for items like drawer bottoms and/or simple frame and panel rails. If you need to use it to cut a more shallow groove, consider placing a thin spacer between the plane sole and stock - in fact, you can tack glue this spacer to the plane sole, to act as a depth stop. This is what I have done with my drawer bottom plane and it works fine.
I would not alter an older plane unless it is a real "beater" and this one looks nicer than that.
Take care,
John
Warren in Lancaster, PA
John's reply made me take another look at your plane, Ron. Years ago when I had a fixed fence plow, I would insert a tight fitting slip of wood (full length) between the skate and the fence to make more shallow grooves. The slip was just held by friction.
Don`t think about what the stop is...
Bob Hackett
Think about what the stop does and how it does it.
Far more options open up that way.
Ron Harper
It acts like a plow except for the depth stop.
Fence fully adjustable
Good advice. I am thinkin
