New WoodChat!
A path paved in gore...
TomD
I was just wondering from reading Bill's post where he sharpened his fingers, how many of us have hacked our way to woodworking success through our own bodies. It is mostly a blur since I was a beginner so long ago, but I remember a lot of minor nicks. The only bad one with actual cabinetmaking tools was when with foot between steel and concrete interposed, I saved a Japanese plane blade from a crash landing, while wearing sandals. That was a gusher.
When I started out, there was a brief period in which is was suggested that sharpening the sides of Japanese chisels to the same ferocious degree as the ends, was a good idea. That created a fair amount of carnage, though all minor, and one did learn to hold the chisels by the handles.
Another source of pain less commonly discussed is collisions With stuff. Fingers overhanging planes. The classic I guess is walking into the vise handle, something I have yet to enjoy. I have experienced a few painful collisions with the sharp edges of the Lee Valley pattern maker's vise.
I did get the base of my thumb with an axe while preparing kindling but that was not really woodworking.
Re: A path paved in gore...
Ron Harper
Two primary ways I acquire small wounds. First, I hold my thumb against the cut line to guide my saws as I make the backward stroke to begin the cut, and forget to remove it as I make the first forward stroke.( at least once a week) remember, sizing stock with hand saws is a pretty new activity for me. Second, honing...and I have no idea how.... But a couple of times per week I get a slight nick. None of this gets to the category of gore.. Did that once with a chisel when paring the sides of a mortise. The stile imploded and i violated the cardinal rule of the shop " keep everything that you want to keep behind the cutter at all times". I really am working on following that rule.
GolfSteve in Calgary
I got a lot of cuts in my early days, especially when I was learning to carve. Then I learned to always keep my hands, fingers, nipples, etc. out of the way of any potential chisel slip.
My worst cut was from a titemark marking gauge. I was tired and when I pulled the gauge over the edge of a board it slipped and put a good gash on the knuckle of the index finger on the hand holding the board.
The stupidest injury was when I was test fitting a tenon into a mortise. The joint was a bit too tight. I was pulling upwards on one piece, trying to get the tenon out of the mortise. It wasn't moving, so I shifted over the piece to get more leverage. The joint suddenly separated, and the piece I was pulling on flew into the centre of my forehead and gave me a good doink and a cut to prove I was a dummy.
Tied for stupidest is probably when I was turning some pens and superglued two of my fingers to a pen blank. It took about 30 minutes of carefully sawing away the skin with my Swiss Army Knife, and soaking my fingers in acetone, to get my fingers separated from the blank.
When I was about three years old I was playing with my Dad's saw. I put a good gash into the hand that was holding the board when the saw skipped out of the kerf. I hid the cut under two fabric bandages criss-crossed over the wound and never told Mom and Dad what I had done because I wasn't supposed to touch the saw. I still have that scar 40 years later.
Self-inflicted battle scars
Bruce McCrory
Have a mental image of spiral-cut ham?
I tried routing the end of my finger. After being shredded, the problem wasn't the wound so much as the folks at Emergency used cotton gauze to wrap it. A few days later, I had to go back to Emergency. I soaked in Dawn, and a very patient nurse pulled thread from healing tissue.
We polished the other nails during... :D
The two I try to keep an eye on are ..
... freehand sharpening plane blades with sharp sides or chisels with zero lands. If the stone slowly turns pink you know that you are gripping too tightly.
... using rebate/rabbet planes. The problem is that I prefer to push the fence against the edge of the board rather than hold the knob (which is safely out of harm's way). My fingers are close to the blade. When it comes to skew blades, I forget that they extend further back (than in line with where I think they end), and so I inevitably slice a finger tip!
Bruce, a MN Galoot
sometimes I'm a little slow on the uptake and cut myself three times (over a several year period) using the same chisel doing the same stupid cut. The last time required several stitches in the ER, and the attending doc remarked that it must have been a very sharp chisel because the cut was very clean. At least I could be proud of something...
David Weaver
Some of my dovetail chisels are hard on the fingers, but I just apply a piece of athletic tape to my finger if I have reason to use them more than a few minutes.
Without fail, the one tool that I get small cuts from if I don't use it just for shoulders (and I never do) is the large shoulder plane.
Re: Knife fright
TomD
For years I had this low angled marking knife. Eventually it sharpened into the hollow back, so I decided to use another one that I had around with a more typical acute end on it. I lined the metal rule and knife up, and promptly cut the end of my finger off. Ok, a shallow slice. I still prefer low angle blades, not only are they maybe a little safer, but they have more surface to align on the edge of the ruler.
Re: Getting the gore out
TomD
I may have mentioned this, and it is no secret anyway. One's own saliva is a great solvent for getting wet blood out of cloth or wood. Of course if there is a huge pool of blood, one is likely to run short of solvent, but for little smudges it works really well.
Quoting you
"Then I learned to always keep my hands, fingers, nipples, etc. out of the way..."
Man, you really get up close to your work!
Re: Quoting you
TomD
For some, the latter amount virtually to an extra pair of hands.
Re: Quoting you
That quote came from a woodworking class I took that had several surgeons as students.
Someone was paring a dovetail by holding the piece up to their chest while nibbling away at the piece with a chisel. One surgeon turned to the other and asked how much he charged to reattach a nipple if the chisel slipped.
Re: Quoting you
TomD
US course?
Re: Quoting you
Nope, the course was in Canada. I guess humour doesn't respect differences in health care systems. Doctors here are often professional corporations, so do submit bills for their work, but there's only a single entity paying the bills - the governement.
Scott in Douglassville
Aside from the countless chisel slips, saw skips, and hammer blows that, inexplicably, have dwindled in number in recent years, number one stupid move was when I dragged three fingers on my left hand over a dado stack. Broken bones, partial amputations, and sawed out the third joint on my middle finger. Which is now 3/8" shorter than it was...
hennebury
My wounds to my body have been many but luckily superficial, the damaged pride however has been serious.
I have had numerous chisel slips. With the amount of scars to my left thumb and index finger its a wonder that they still function. Have also ground the tips off my fingers several times on various sanding machines.
And routed a groove through one fingertip.
Slipped once when pushing a heavy low box across the shop floor and stopped from hitting the ground by doing a face-plant on the box.
Recently, tipped a 600Lb machine over on myself and was pinned to the floor, I had to scream for my wife to come over to the shed to rescue me. Nothing broken, wrists were all cut up and also needed a few stitches in my foot, a bit of bruising and soreness that was all.
Then there was the time that i wore a pair of safety shoes in the shop: they had steel toes and an instep guard, well i had a lot of heavy maple planks in the shop and thought that i should be safe.
Well the first day i had my new safety shoes I wrestled a huge 2" thick maple plank off of the stack, (it was just a couple of large heavy boards on the floor with stickers between) them and tipped it on its side heaved one end up under my arm and dragged it, oh all of a couple of inches i guess before it snagged and pulled out of my hands, well down it went, struck a protruding sticker on the boards on the floor and catapulted the sticker into my forehead and knocked me on my ass. I looked up with blood running down my face to see my trusted assistant laughing his ass off.
I never really put any faith in safety equipment since then.
I used to have a bad habit of throwing chisels in the air and catching the spinning chisel on the way down, .... Got a 1/2" boxwood handled mortise chisel stuck in my knee once, hit a pumper too, spit out a lot of blood, all ran down my leg and pooled on the floor. The doctor of course was suitable impressed with the clean incision.
So nothing major or debilitating yet.
I had an acquaintance a few years ago that trimmed all his fingers from his left hand off dead level on the table saw. So all of his fingers were the same length. He used to be a heavy drinker and always worked in his basement hobby shop with a scotch in one hand ( single malt I believe) well his family were constantly telling him to quit drinking, which he did...just before he cut all his fingers off.
Hmmm.
Re: Quoting you
TomD
Makes sense Alberta is more advanced on that score.
