New WoodChat!
New Japaning . . .
New Japaning . . .
New Japaning . . .
steve mackay
In the past, after bead blasting, I've always run some sand paper over the areas to Japan. This time (5 1/2"C" & 7 "C") I got cocky and skipped it. Don't do that ! The stuff "flowed" just fine but REALLY telegraphed every little thing. Live & learn.
Re: New Japaning . . .
TomD
What are you Japaning?
5 1/2 "C" & 7 "C" Stanleys
Just curious
Patrick Gibbons
Can you remove and reapply? Also where do you get your asphaltum these days?
Re: Just curious
steve mackay
Since I kinda made a mess of it (in places), I tried smoothing it in places with a rag and acetone. Made it worse. The most that HAS worked is to scrape off the ugly then dab a nit more on and let it flow again. This has to be done in the middle of the curing schedual. There are four or five temps and times. I got the goop from "WAG Japaning, LLC". Guy named Gustafson at oldtools@taconic.net. (581)392-2845. His stuff doesn't stink up the house or oven either.
