New WoodChat!
Have a question? Ask Woody!
Interesting light sensitive dyes
CJ in MPLS
I was just looking at Kickstarter this afternoon and saw an interesting dye formulation that allows one to photoprint on absorbent surfaces. Apparently the dyes go on as a light color and get stronger with the application of sunlight, i.e. they develop. Once you've reached a certain color saturation, you remove the remaining/undeveloped dye from the substrate by washing. The washing could be a problem on wooden surfaces, but could be overcome by printing small areas instead of the entire surface.
The product is mostly intended for fabric, but can apparently be used on any absorbent material. One of the examples I saw was as small purse on which safety pins had been left to rest. The purse was a pink color, but the very sharp image of the pins were in white. I could easily see a leaf or other found objects being used to form images in lieu of veneer or carving. Shading could provide a very neat effect as well where the exposed side of a piece is fairly bright and the off side shades closer to bare wood. Granted, similar kinds of solarization is often seen as a problem with wood color/finishes, but could be interesting.
I'm a patent attorney in the semiconductor industry and not affiliated with the supplier.
CJ
http://help.lumi.co/customer/portal/articles/200654-how-should-inkodye-be-used-on-wood-
Re: Interesting light sensitive dyes
TomD
Flytiers used to dye various greys using photo supplies.
