New WoodChat!
Veritas Miniatures
Veritas Miniatures
Jack Guzman from Maine
Veritas Miniatures
I have all four of these neat little tools. I have tried each one on a scrap of wood and found that they are all totally functional. This is the first time I actually needed their unique size on a job. I repaired a high chair. The tray split in half with the grain. It has holes left from an old repair that used metal L brackets to hold the pieces together. After this it was repaired again by putting dowels in both ends. These were poorly lined up and didn't hold the halves together. I removed the dowels,planed both edges of the tray and glued them together.Once the glue set I added dutchmen to the bottom surface to span the split. I cut the butterfly shaped dutchmen with a small handsaw. I cleaned the edges with a paring chisel. One end was rough from the saw so I trued it with the mini block plane.Also one face. To make the mortise I looked to my router plane with a small bit but the base of the bit was too long to be of any use. Then I tried the mini router. Perfect. Just the tool for the job. This little tool works very well for smoothing small mortises. I will be using it more often I can see now.---Jack
Re: Veritas Miniatures
Dang it, Jack!
Bruce, a MN Galoot
I have the mini-shoulder plane and have found it very useful, for its size. I've successfully resisted the router until you piped up. A friend has asked me to fix a couple (not really antique as he thinks) chairs and the mini-router would really be the ticket.
"Those" tools . . .
steve mackay
. . . you never knew you loved 'till ya' got 'em ! I've stood there studying a move for an hour then thought "I'll bet that mini shoulder plane'll fit in there !" Sure enough, it did. SWMBO got me that "inset" plane for Christmas. Some day soon that Muse with the sledge hammer is going to have a clever idea about THAT one and . . . bang, bang, Maxwel's Silver Hammer . . .
