New WoodChat!
ThomD, do you remember the knife maker,
Tom Colligan
who made his own welded angle iron jigs for sharpening? You posted a URL to his video a few months ago and he appeared to have diamond shaped teeth. Can you direct me to his URL as I've been trying to locate it but with no success. Thanks,
Re: ThomD, do you remember the knife maker,
Re: sadly
TomD
Unfortunately some guys ganged up on him and made YT take the video down because it was unsafe. Probably most things in a KMs shop are unsafe, but I think his stuff was no worse than most.
His jig was that he had a wheel, and a flat rest in front of it. He had two pieces of plate welded to an angle so that when the blade was clamped to the plate with a vice grip style welding clamp it was presented at the correct angle to the stone. He did not say, but I would get that angle by measuring my knife thickness and height and overlapping the radius of my wheel to provide a proper hollow ground (could also be flat). I would model that in a little piece of wood. hold it against the wheel, at the expected height, and I would then use a bevel gage to get that angle and from that I would set the angle of my jig. I guess on could make it adjustable. One could also make it out of wool and maybe screw the blade to it.
Each knife has a perfect jig for wheel, jig, blade, and rest. The jig moves freely on the rest.
The straight part of the blade from grip to bend can be ground from the jig, however, when you get it to the end, on most knives the curve will require you to use some english.
Re: sadly
TomD
Here is a home type one. If you start around 2:00, you will notice that he keeps the same angles to the face of the belt as he gets to the tip. The rest of the bevel is getting ground, at say, 25, but the point needs to have that angle also, and the way you get there is to pull back on the left hand as you get to the tip. He gets that result mostly and may explain it...
Re: sadly
Tom Colligan
Thanks, Thom, but there was no URL posted if you meant to include one.
My apologies men as this is OT but, Thom, would you know his website as he seemed to sell knives and I'd like to contact him, if possible.
What are some of your favorite sites for knife making or knife forums, Thom?
Thanks, tmcolligan@comcast.net.
Re: sadly
TomD
Sorry been sick.
http://www.youtube.com/watch?v=RhzsiGkq8II
The other guy is called Mike Snody. He has hundreds of videos on youtube a new yorker friend did not mesh that well with him and said he had not thought to live long enough to see see the gangsta redneck hybrid. Or something like that.
Snody has so many videos that the jig may be there in another one, but I think time would be better spent searching stuff like knife bevel jig, or bladeforums.
Re: Bubble Jig
TomD
https://www.youtube.com/watch?v=FY8fqasGWps
Patrick Gibbons
There's a video on a jig for scandinavian grinding. Google how to make a scandinavian knife and it will be there. I think it was justjoel or something like that. For fun take a look at Ragnar's Ragweed Forge.
TomD
Neat, Patrick, I have a friend who will probably like that site!
Re: Bubble Jig
Fred W. Rowe
I saw this thread on a Google search and thought I should give you a link to my site. It may add something to the discussion. [url]bubblejig.com[/url] E-mail me if I can be of service, Fred
