Re: Embarrassing dovetail problem. HELP!
Wiley Horne--So. Calif.
Patrick,
Coupla three options:
1. Make some time. Let the person know it'll be a little late, so as to take the pressure off yourself so you don't have to work and think under time pressure.
2. Hide glue, part 1. Following on what Jack said, if there is any room in the joint, or if you can flex it a little to make room....Get the liquid hide; heat it gently to 90-100 degrees beside a heat source (this gets it thin and runny); pour the glue into the syringe barrel of a number 20 syringe from the local feed store (get an 18 and a 22 for good measure); inject the glue into whatever niches you can find or make in the joint. Try from outside and inside.
3. Hide glue, part 2. As before, heat the liquid hide to get it runny. With the box held horizontal and the failed joint due south making a V aimed toward the ground, pour the glue from the inside, letting it make a standing pool in the failed corner--if the joint is not too tight it'll seep in, maybe enough, keep heat on the pooled glue with a hair dryer....Clean-up is straightforward with water.
4. Reinforce the corners. If the joint appearance is presentable, or can be made so by touchup, then make attractive corner braces, the height of the box, to fit into each corner. These are L-shaped in section, height of the box, covering the inside of the four corner joins. Sculpt them to make them look nice.
Of all these, the hide glue ones are best, in that they will tend to swell the joint, making it look 'growed together'.
Wiley
