A little help needed
Ron Harper
Going to make several small wooden Crosses ( 2.5 in tall. 3/8 thick ) for a Mission to sell in their gift shop.
What is the best glue for the half lap joint?
Thanks
Ron
Ron Harper
Thanks
Ron
Titebond III
Patrick Gibbons
Or 2 or any other yellow glue. Not sure what your concern is. I've glued half lap joints with Titebond and they're still doing fine.
Cross grain
Re: Cross grain
William Duffield
On an item with boards that narrow, cross grain shouldn't be an issue. End grain would be an issue, but you should have plenty of face grain surface to hold it together.
Liquid hide glue..
Jack Guzman from Maine
is what I use when I build a cross. Only because I like working with it. Just about any glue will work for this application.---Jack
Re: A little help needed
TomD
Titebond 1 is possibly the most proven crossgrain glue out there. Guitar guys use it for gluing bridges in situations where the string load is 100 pounds (with up-pull, rotatio, and energy through vibration), there is extreme cross grain, and there is no end grain support, and there are dissimilar woods. I like to use Titebond 1 when I am selling stuff because of the track record. Hide glue is another glue with a good reputation. Both assume no water, which would probably apply here. T II, or T III might be better, but there are not a million guitars out there saying so. The bridge is only one of the cross grain situations in a guitar. There are also endgrain situations, and endgrain with crossgrain. Guitars are sometimes taken great care of, but a lot of them are abused, the stuff works pretty well either way.
Epoxy would be better, but I don't see any reason to go there in this case.
If you want more security
Patrick Gibbons
Use a dowel or a Miller dowel. Even a visible dowel where you drill straight through could be made a decorative aspect. Because there is no stress put on the joint, I don't think it's a problem.
