Experiments in wood drying.
Jack Guzman from Maine
I have a new toy. I need to play with it.
I built a more efficient kiln for drying chair parts. I lined the underside of a wall mounted bench with insulation board including sides and doors and put in cleats for a removable rack. In the bottom under some screen are three standard ceramic light fixtures. I use 150 and 200watt bulbs(whichever is on the shelf at the local hardware).It also has a thermal switch that cuts off power at 125 degrees.I left an opening at the bottom of one side of the cabinet and have a computer fan in an opening at the top on the opposite side pulling air out using a 12v battery. This works great . I used it to accelerate the drying of a couple bent parts in their forms.
Friday morning,I bought a fresh cut maple log for leg stock. My grandson and I busted it up into leg blanks roughly 2" square by 24" and stored them in a shaded place outdoors. I decided to experiment a bit.
I put four pieces into my kiln ,planning to dry them a bit before turning. They are way too juicy as is. 12 hours in the kiln I took them out and had a shock. They had all checked. Cracks in all ends and some running the whole length of the blank. The wood opened up pretty wide in places.I learned that I can't do that . Gotta wait for gradual air drying, so I put the ruined blanks on a shelf for the time being. Went down and looked this morning and alot of the checking is gone.
This makes sense. The moisture trapped in the center has spread throughout the pieces stabilizing them. Now I'm wondering if the fractures are still separate but just unseen. Will these pieces be useable after all or will they come apart where they cracked.
I will turn one of these when it has had awhile to dry and I will report the answer to the above question.---Jack
