Re: OT - mouse/rat control in crawl space
Bruce McCrory
There is a wood working solution, that gets this OT onto On Topic. But first, from the experts, and me, after several hundred dollars to the experts:
We have both Norwegian and native roof(?) rats in western Washington. The roof rats are smaller, but much uglier varmints. Those nasty tails are longer than the body. Rats move in during cold weather. They used the hose bib opening that was without a scutcheon plate to get to our basement plumbing wall, then up into the ceiling-first floor cavity. I couldn't put my thumb through the gap. Roof rats can run along the eaves or wall trim and bob under exposed truss tails. Vegetation needs to be clear of the house by about 4 to 5 feet.
The best way to stop rats is stop all openings as small as a quarter. Use metal scutcheons, sheet metal, or heavy wire webbing, like for rabbit cages or sifting dirt. They will try to chew through wood at a familiar access; and aren't bothered by copper wool. A nursing mother will tackle even wire. Rats are smarter than children, definitely smarter than teenagers, and will learn to avoid hazards. How ... Smell? Who knows?
If they are in the house, don't plug the outside accesses until you have removed them, by luring them out. As noted, poison is not a good solution in the home. You probably won't be able to get to rotting carcasses. [Bill, you were really lucky!] Poison should only be used where pets can't get to it. Poison is one of those things they learn to avoid, too. They can also get at an open spring trap after raccoon, cats, and dogs mess with them.
But they love peanut butter. And, here is how you get them every time:
You know the Victor Brand Spring traps? Use them. Victor has a plastic base version, also. Nothing else works. Period!!
Now you build the "safe and cosy" trap mansion.
It is a three chambered box (four walls). I made the chambers the same size, lined up side by side. The trap resides in the middle chamber. This "room" is wide enough for the trap to slip into, long enough for its length and, maybe, two to three free inches for the visitor at the doorway. Make him/her squeeze and keep things very snug.
The box is fully enclosed, bottom, top, sides; and the two interior chamber walls are full height. Height is based on the length of wire swing. All holes were about 1" to 1-1/4" size; I knocked them out on the bandsaw. I didn't want to deal with squirrels, so kept size smaller than my brain thought was needed. Trust the spec's.
Keep in mind that the trap will jump, so nail it down. Rats are fast! And, a trap hung up for even a micro-second will miss the guy. All of my guests had snouts only a tiny fraction of an inch too long.
The top lifts off for access. Also, mockups help because it's awkward setting the traps. I set rat killers in place. You can't drop them in or slide them like mouse traps. Some bricks on the lid will keep most casual interest from pulling off the lid for the peanut butter.
The two abutting chambers are for the rat to hide in while it investigates the sumptuous presentation through the inner door. I lined up the doors, but placing the exterior access openings at the opposite sides of the inner openings will get the victims bending in a "U" to reach the peanut butter. Anything to slow them down.
Place the trap mansion near the access hole, or in a secluded hidey spot next to the foundation. They won't feel so exposed this way. Two traps per house are recommended by the pro's.
Go get em'!!!
