Milling for Maximum Thickness
Steve Elliott
This is the best tip I can give for getting the most out of a piece of lumber and it's sure to start an argument. I'm posting this in a new thread but it was kicked off by Bill Tindall's comment, "If removing cup, start with the convex side up [when using a power jointer]."
To get a straight board of maximum thickness and width, start by removing stock from the middle of the convex side of the board, or the middle of the convex edge. Most wood leaves the kiln in a case-hardened condition, which means that the outside of the wood is in compression and the inside is in tension. When stock is removed from the hump in the middle of the board, the balance of tension and compression is disturbed and the board bends a little and becomes straighter. When the first side or edge is straight, the board is thicker or wider at the ends. When the second side or edge is worked to produce a parallel surface, very little wood needs to be removed from the middle of the board so its overall shape doesn't change much.
Of course not every board is case-hardened so this technique doesn't always help, but it works about 2/3 of the time in my experience. When I'm done milling a pile of boards it's the case-hardened ones that are the straightest.
I spent today milling oak and maple for drawer parts. Of the stock I used I'd say 85% was case-hardened. I'm always a little disappointed if stock has had all the internal tension released in drying, which can be done by an additional step at the end of the kiln drying process.
Usually I try to stay out of arguments and don't like to start them, but this is one of the things I've learned over the years that I think other woodworkers would appreciate knowing about if they realized how helpful it is.
I never learned to "wheelie"--front wheel hand brake action--hand planes at the end of a pass; it's more like a golf swing. This will be training.
