gluing stuff- frames
There is a key element to success. I learned it in the class I took in the Mack Headley and Sons shop. If the joint won't go together with hand pressure it is too tight and needs adjusting. This is where hand tools excel- fitting. Obeying this rule pays off later when the glue is applied and the joint begins to swell. Well, there is a second rule. First dry glue these assemblies. It gets the clamps preadjusted and in order. Also it tests the assembly strategy and reveals problem joints.
Study the possible ways to proceed. End the gluing with the easiest step possible. This bench frame will be assembled on its end to take advantage of gravity. Gravity is a good helper, or thwarter. I applied glue to the mortises first as it dries slowest here, and then the tenon cheeks. I use a brush and spatula for spreading. Work quickly and get help on something very complex. My wife and daughters are experienced glue appliers and they are called upon when needed.
For the task at hand, first I worked on the short stretchers for the bench ends doing each in turn with them laying flat on the bench top. Then we applied glue to the mortises and tenon cheeks for one end of the long stretchers and stuck them into the mortises. At this point these long stretchers are pointing perpendicular to the earth. Then the mortises and tenons on the other end were juiced up and this assembly(the other bench end) hoisted up on the long stretchers pointing at the sky. Gravity then lent a hand as this end assembly settled upon the tenons sticking up in the air. At this point the frame is assembled but it is on its end. Then two of us rotated it into its normal horizontal position and clamps were applied.
Because none of the joints were too tight each of these steps resulted in the M&T joints being largely seated. This accomplishment makes things go vastly easier.
M&T joints are slow to dry. I leave them in clamps at least 24 hours, with 48 better.
