We value your privacy.
In the thread below about planing, my sanity was questioned because I size my tabletops very close to thickness before glue- up. Is this so weird? With a flat gluing bench and proper preparation this has become pretty routine for me. I would really have trouble if I tried to glue up complex assemblies the way Bill does in a post below. My hat is off to him. I'd love to stop by his shop someday and learn how he does it.
A lot of people on the internet are very attached to their own way of doing things, but if your methods produce the result you desire, then stick with them. Eventually your methods may need to evolve to meet changing goals, but in the mean time don't sweat it.
I don't recall the thread, but sizing the table parts prior to glue-up sounds to me like standard practice, assuming one does not have machines large enough to take the parts, or reach long enough to do it by hand. Even then, the best yield of stable parts comes from finishing the sub-assemblies first. Same principle as best yield in sawing comes from breaking the board out first.
Most panels I've glued up from wood that I bought S3S and had minimal planing to do after the glue up. On the occasions where I have used rough, unsurfaced lumber, I would plane any cup, warp or other problem from the individual boards but wait until after glue up to do my major surfacing. This was to bring the panel to a consistent thickness. I read the thread below but not thoroughly. I suspect some are leaving out some detail on their procedure. If the boards I'm starting out with are flat and smooth then my panel will need very little work. Essentially just cleaning up the glue lines. There's usually no surprises about how much work my panels are going to need because I can tell going into the process what's going to be needed. If I rush a glue up before I perfect the butt joints, I always have more work to do on the panels. Maybe you and I are both blissfully ignorant.
I can get a surprise, but it does not happen often. I do agree with Roger that if much thickness needs to be removed, it needs to be done over a few days to allow for movement in the wood.
Why would the wood move if you had already let the wood move. If it moves every time you do something, then there isn't any end to it. My wood is done by the time I start.
Don't know about roads up mountains and all of that half-existential stuff. In Planecraft, broad surfaces are planed after panel glueup, not before. Ditto Joyce, Frid, Hayward, Ernest Jones, and on and on.
An internet connection is generally a poor substitute for a woodworking library, though here is a little ditty from Jeff Gorman's website - the section on making a panel joint:
"It is really desirable to work with material that is thicker than the intended finished dimension. The entire surface can then be planed after the job has been glued."
Use a combo square like you always do and then tweak to get the boards generally vertical - I test it with boards in the vice usually. Register the combo square on the concave side of the board, not the convex side (everything has a little cup).
It sounds impossible. I swear before God it's not. If you want to, you can clamp boards back to back and plane the edges at the same time - boards DO NOT have to be flattened first for this to work.
My working approach is that all panels will go out of flat when glued and clamped, so I try to get the downside as flat as possible, planning to just have to do some touchups there. For the other side, I plan to take out all the non-flat possible. That's it.
