New WoodChat!
Odd fixture
Odd fixture
Odd fixture
eliot d
I found this odd -looking thing in an old box in my shop. It's a small metal cylinder about and inch long, about half inch in diameter with hole about a quarter inch in diameter right down the center; combined with it is a kind of drill bit that fits very smoothly down the center through the cylinder. I believe it is part of some kind of little kit to make wooden hinges that I bought years ago. But I can't figure out what do do with it. I figure it has something to do with proper drilling of the hinge "shaft", but I can't see how to use it. Any ideas? It's really just a cylinder and a bit.
Re: Odd fixture
Re: Odd fixture
Wiley Horne--So. Calif.
Does the cylinder have an Allen screw (or similar) through it to enable tightening it onto the drill? If so, it may be a stop collar. If, in addition to a tightening screw, the cylinder is sorta conical at one end, it may be a countersink.
If no means of tightening, the cylinder may allow for centering the drill within a 1/2" hole (counterbore) that you've already drilled. Where the counterbore provides a recess for a screw or bolt head (with washer usually).
Wiley
Re: Odd fixture
Re: Odd fixture
eliot d
Thanks for trying to figure it out. No, there's nothing except a straight cylinder and a drill bit. The whole thing is very carefully made. I still think it has something to do with making a wooden hinge.
Re: Odd fixture
Re: Odd fixture
jack curtis
It could be a self-centering bit, which would normally be used for hinges.
Re: Odd fixture
Re: Odd fixture
James Watriss
Makes sense to me, kinda.
...Be aware, totally pulling this directly out of my crap factory, but based on your supposition that it's for wooden hinges...
I think the deal is this: the bit fits the cylinder, meaning it'll drill a hole for a dowel that would also fit inside that cylinder. The cylinder itself, my guess is that it's a drilling jig to drill a centered hole through the dowel... You'll need the matching bit for that, of course... So that the dowel can be pinned in place in the hole drilled by that bit.
That's my guess.
Is there a photo yet?
Re: Odd fixture
Stephen Shepherd
Re: Odd fixture
Stephen Shepherd
I think it is a sleeve that fits in the old style Stanley doweling jig. The jigs came with several sleeves of various sizes.
Stephen
Re: Odd fixture
Re: Odd fixture
eliot d
I finally figured out what it is: is part of a Beal threading jig. The cylinder fits tightly into a hole that's perpendicular to the dowel that's being threaded, and the drill-type bit is actually a router bit that actually cuts the threads as the dowel is advanced past it. (But I bet I can figure out some way to use it make wooden hinges.)
