New WoodChat!
Last Present Made
Last Present Made
Last Present Made
Patrick Gibbons
Here's my last Christmas present. It's a tea caddy for tea bags out of maple. I made the hinge and then figured out two better ways to make it. Oh well, the next one will be better. There's two compartments, one for black and one for green. Thanks for looking at my holiday projects. Happy holidays to all and good projects in the new year.
Re: Last Present Made
Nice little box - simple but clever
Wiley Horne--So. Calif.
Very evocative, Patrick! Reminded me of turn-of-the-century like you would see in a Carl Larsson print (except it would be painted in his case). Will see many a good day's use.
Thanks for sharing!
Wiley
Robert Tutsky
Robert Tutsky
Very nice box Patrick. That's a box I could actually use as I like both black and green teas. Question is, how is the hinge constructed? I don't see a pin going through the hinge leafs. I have a project in mind that I would like to try my hand using wooden hinges.
Patrick Gibbons
I drilled a 1/4" hole through the pins and inserted a dowel. It disappeared with sanding, both parts being maple. I've determined a more elegant way to make it and one that works better. One door has only one pin and it is not as stable as the other door with two pins. Next time I'm going to use the lathe to shape the ends that anchor the hinge to the box and I'm going to spend more effort on shaping the hinge pins to a pleasing round shape. There will be at least two pins on each door. At this point I want to build a few more to experiment with the concept and refine it. I'll post as I go along.
Hinges!
I have hard enough time with precision metal hinges and getting them right. You make a convincing case that given enough experience and skill wood hinges are possible. Must add to things to learn and do list. They sure look neat on a box like this one.
Robert Tutsky
How about something like this...
Robert Tutsky
I could see what you mean by the door with one pin wouldn't be as stable as the other door with two pins. I would think that each door having two pins each would work. This quick drawing shows how it might work. It could be cut using a box joint jig on the table saw or router table. The tricky part would be to accurately drill through all pieces. When I tried something like this in the past, the drilling part is what I had trouble with.
Robert Tutsky
Oops... corrected drawing...
Robert Tutsky
Re: Oops... corrected drawing...
Patrick Gibbons
That was one other way I thought to do it as there is a divider in the box to divide the two compartments and it could be tall enough to include the hinge. I did not do it that way but think that is the best way to do it. I cut the pins by hand and chiseled out just like making dovetails. Then marked the other top door for its pins. I then used the drill press to drill one top, fitted the two pieces together on top of the box and used the previously drilled holes as a guide to drill the other top. I also thought about turning a dowel about 1/2" size and drilling out on the lathe to be used as the ends of the hinge, attach those to the box, fit the two tops which have been previously cut out and use the two round ends as guides to drill out the tops. I think the round ends would look very elegant but the use of the divider as the hinge anchor would be much easier and effective. I'm going to try both ways and see how it goes.
