New WoodChat!
Lesson learned
Lesson learned
Lesson learned
Ron Harper
Lots of things to learn/ re-learn after a long layoff and a switch to Galootish woodworking. Was making these as Christmas gifts for friends and at one point in the process was drilling into end grain of the very hard curly maple. Tried to use Jennings bits. Bad idea. Brad points are the way to go in end grain of very hard wood. These gauges turned out to be Beta versions. Not very happy with the fit of the mortise. But I learned there also. I think I will give the gifts anyway and tell them that they will be replaced soon. I will do the mortise and then very carefully plane the shafts to fit. Not enough time to re- do before Christmas.
Re: Lesson learned
Robert Tutsky
Re: Lesson learned
Robert Tutsky
An easy way to have the mortise automatically registered to the beam is to cut the beam first and using the same stocks cut two adjacent pieces that sandwich the beam. Then simply glue a top and bottom to the adjacent pieces and you're done.
Re: Lesson learned
Re: Lesson learned
TomD
Where was the endgrain drilling in that? Best drill for really hard endgrain is speedbore, or a boring rig in a mill or a lathe, but accuracy is a problem with the speedbore. But if you want to know what cuts fast...
Re: Lesson learned
Re: Lesson learned
Ron Harper
Was going to do a thumbscrew in the end to secure cutter. Changed mt mind
Re: Lesson learned
Do not want glue lines
Re: Lesson learned
Slightly loose gauge fit can be good!
Wiley Horne--So. Calif.
Hi Ron,
Here's something I found counter-intuitive when I first heard it, but then it makes sense on reflection....
The gauge-maker Colen Clenton does not try for a perfect fit of the arm in its channel. Instead, he bevels one face of the arm, so that when the screw is tightened, the arm is twisted slightly in the channel, forcing it into positive contact on two faces of the channel. This locks the arm both vertically and horizontally, so that it is square to the stock's face, and can't move.
The claim is that the traditional method of shooting for a 'perfect' fit will tend to lock the arm in the direction of applied force by the screw, say vertically, but then it will have to have some play laterally (otherwise you'd have to adjust the arm by hammer taps). Whereas, if the screw forces the arm 'into a corner' so to speak, it has no way to move beyond that, and there's no play left.
Maybe you have it exactly right!
Wiley
Re: Lesson learned
Re: Slightly loose gauge fit can be good!
The later Stanley No. 65 marking gauges used a similar approach, with the bar having one corner of the square shape rounded off, and the thumbscrew pressing against the center point of this "corner," and thus pushing the opposite corner into the head. An elegant design.
Re: Lesson learned
Ron Harper
I have cut several gauge lines with these and they are accurate?
