New WoodChat!
stanley plane threads, and obsolete thread standar
bridger berdel
as a tinkerer-with-old-planes, I have a hankering for some hard to find taps and dies. there are sources for 12/20 taps, but they are usually out of stock, and a bit pricey. a 12-20 die can be approximated by cranking down on a 1/4-20 split die- it works pretty well. I have a friend who inherited a bunch of obsolete tooling from his dad, who was a railroad machinist (I think). anyway, he has a 3/16-20 tap. anyone here have a clue if that will cut an acceptable thread for stanley's 12-20 plane handle stems?
Re: stanley plane threads, and obsolete thread standar
I've always just re-threaded for 1/4-20
John in NM
And replaced the rod with all-thread. My replacement handles usually end up being taller than the originals by just enough to need a longer rod :D
A #12 has a major diameter of 0.2078"-0.2150". 3/16" is equal to 0.1875". So, probably not. You could try it, certainly - see if it works.
Re: Is 9.50 too high?
TomD
http://www.victornet.com/alphabetic/Taps-Special-Pitch-up-to-1-2-quot-/213.html
http://www.practicalmachinist.com/vb/antique-machinery-history/i-need-12-x-20-tap-dies-114720/
If you have a tap, making the dies is not that difficult, you drill a central hole, then drill a cloverlead of holes around it. You then tap the center hole and heat treat the piece, which being small might be possible with a regular torch.
KBC.com has a 12x20 die for 12.22 page 126.
john sayles
The Victor route sounds good till you realize that there is a 25.00 minimum order before freight, tax, etc.
Not really a big deal, but a year or so ago, when I was about to order such a tap, I couldn't for the life of me, find anything I really wanted/needed to reach the min. order mark. I even considered ordering a second 12-20 tap, but that still wouldn't have cut it.
I've bought BS blade stock from them...
John in NM
About the best price as I remember.
TomD
KBC has both, not sure what the minimum is.
Jim DeLaney, Austintown, Ohio
Go Metric. A 6mm coarse thread will work. It replicates the obsolete Stanley thread almost exactly.
