New WoodChat!
three blades, three chipbreakers, one plane.
bridger
Bridger
today I hung a door. for reasons I won't go into here I knew I'd need to do some heavy planing, so I brought three cutters set up with chipbreakers for a #5 plane. one with a heavy camber(use a short chipbreaker for that one), one with a little camber and one sharpened straight acrosswith the chipbreaker set close. this setup worked so well I'm thinking of a way to make a travel case for multiple blade/chipbreaker sets. just a little fiddling with the depth setting and lateral adjustment, plus a turn or two of the lever cap screw is all you need to completely change the performance of your plane from near-scrub to near-smoother.
Bridger
Re: three blades, three chipbreakers, one plane.
Patrick Gibbons
That's the thrifty and space-saving way to do it. It's really good to hear it worked for you. A canvas roll would be a space saving way to carry the sets.
Re: three blades, three chipbreakers, one plane. *LINK*
A thorough development of an old idea - and therefore a new idea. Good thinking.
I don't know if Lee Valley's plane cases would work (linked below), but I'm inclined to agree with Patrick that a canvas tool roll would be simplest, although you'd probably have to make it yourself, unless you wanted to buy a chisel roll and remove the stitching between adjacent pockets until you got the width you needed.
http://www.leevalley.com/US/Wood/page.aspx?p=69539&cat=1,41182
Question
Al Goldstein
Wouldn't the plane need an adjustable mouth? Scrub planes need a wide mouth and smoothers need a narrow mouth.
bridger
Re: Question
Bridger
the mouth is pretty open on this plane. I suppose you could say that's why I'm calling it near-scrub and near-smoother performance rather than scrub and smoother performance. a #5 is a bit long for a smoother and a bit wide for a scrub, too, but all in all it worked out well for the softwoods job I was doing. if the chipbreaker is set close the tight mouth is not so important. for this many blades one plane setup a thick blade could be used for the smoother blade to close up the mouth for that operation while leaving it open for roughing out with a thinner blade that leaves the mouth more open.
Unlike 3 irons in-waiting
Bruce McCrory
Trying to find immediate use for my LV LAS extra irons. I think I will cut a Stanley 220 at the desired bed angle, and sweat new shoulders onto it. Then make another for the third bevel angle.
