New WoodChat!
Simple and useful technique--shooting edges
Wiley Horne--So. Calif.
Hi All,
This will be old hat for many, but it's so simple and useful that it may be worth mentioning anyway. Technique for shooting thins, or really shooting any edge.
Here's the setup. Two sheets of flat ply, and a plane which is straight and square in section. The plane runs on the bottom sheet of ply; the work will be placed on the top sheet of ply--the lighter sheet in the photo:
http://www.flickr.com/photos/78661951@N07/8262578644/in/set-72157632172323442
In the next photo, the work has been added, placed on top of the upper sheet of ply. The top sheet of ply is there just to raise the work into the blade of the plane. The work, a 1/8" sheet of sawn veneer, has its edge extending into open air:
http://www.flickr.com/photos/78661951@N07/8261509377/in/set-72157632172323442/
The plane is run along the work: work from the inside, planing the middle of the work first, gradually lengthening the stroke as the work comes straight. Finally a stroke for good measure along everything but the ends; then end to end. You can easily see when all irregularities are planed away.
I find it fastest to just hand-hold everything, using no clamps. One hand on the plane, the other hand holding the work in place. It goes very fast. Nothing wrong with clamps, though, and they would be useful when shooting a thicker board, such as a 4/4 piece for a desktop, say, just to get an extra hand.
Good for preparing thin edges for joining, such as sawn veneers, drawer bottoms, dust panels.
Also a good technique for thicker boards, for anyone having difficulties getting a square edge with the work held vertical.
Wiley
Re: Simple and useful technique--shooting edges
A variant
Frank D. in Montreal
Hi Wiley,
Another variant is to sandwich the piece and prop it up on a piece of scrap. Pretty sure I learned this from Krenov (a book of his...).
Re: A variant
Hi Frank and all,
That would be especially good if the work has a bow to it and doesn't want to lay flat. Which would certainly be typical.
Are you somehow registering the cut off the edges of the sandwiching boards? Or is the work projecting, so that you're registering the plane off its side, and letting it ride the work?
Wiley
Re: A variant
I usually use two jointed boards (quick work with short pine scrap), then let the veneer (or thin board) stick out just enough to clean it up before taking the last few shavings along the entire length of the pine boards.
Re: A variant
Bruce McCrory
I was taught to pin the edges (both) between backers, also, and shave in both directions. We didn't sharpen past a dry Norton back then, but loose corners are still very prone to tear out.
The plane can ride the work
Check out what this guy does, starting at about 1:00 into the video. Same principle works with longer sticks too, working from the middle outwards toward end-to-end.
Then visualize yourself making up drawer bottoms (for example), using sticks from your 'shorts' pile.
Planes are self-jigging--the plane can ride on the work and produce a straight edge--works the same, whether or not you put a flattening board on top:
http://www.youtube.com/watch?v=hwzeONtOAFg&feature=BFa&list=WL5D8A2859F0DDF1DD&index=3
Wiley....Thanks to Bruce (and earlier Wilbur) for original posting of video.
Re: The plane can ride the work
Makes sense. I can see that technique being sort of equivalent to using an edge-trimming plane (which insures a 90° edge). The sandwich that I showed is specifically meant for veneer, which as you know can chip or break even when planing with some kind of shooting setup if not careful. Gnarly veneer like burl is especially fragile...
