New WoodChat!
Gun stocks
Gun stocks
Gun stocks
eliot d
Anybody make these? A fellow wants me to make him one. I know nothing about it. Where would I start?
Re: Gun stocks
Stephen Shepherd
Re: Gun stocks
Stephen Shepherd
What kind of gun, modern or traditional? Most gun stocks are made of walnut or maple, particularly curly maple. Some were made of cherry [I am talking traditional muzzle loading guns, but also used on modern stocks], ash and sycamore.
Stephen
Re: Gun stocks
not a novice undertaking
Bill Tindall
Many ergonomic variables are involved in addition to the obvious task of fitting wood to metal. A well fit stock enables a near instant sight pattern to be established. An ill fit stock renders the gun annoying at best.
Re: Gun stocks
Re: Gun stocks
John in NM
Start with Al Linden's book if you can find it. If you have a high tolerance for fussy hand fitting, you should be able to do an acceptable job following the book. This book has been re-printed umpteen times, so you can usually find the three volume pamphlet version fairly cheaply. Might even find a kindle version, I've never looked.
Do not take money for the job if you do it though. First and foremost, because you'll make about $0.50 per hour and end up hating it - do it for free and you might enjoy it as a learning experience. Second, technically you get into a very grey area when taking guns in for paying work without a federal license. If you want to follow all the long and confusing minutia of it, forum discussions on the subject are easy to find (and generally of questionable accuracy).
Re: Gun stocks
Forgot...
John in NM
If you look for the books, search "Alvin Linden" rather than "Al", that will keep google's idiotic auto-correct from changing it to something else.
Looks like Amazon currently has the three volumes for sale separately, you could skip the last one on finishing unless you really want to choose a specific old method to use. You probably won't find many surprises in there though.
Re: Gun stocks
I'm making one now
Bruce, a MN Galoot
As John said, it's not a paying enterprise. Mine has been a LOT of work.
Some random thoughts:
I can't imagine inletting the action without power tools, this is a router table operation at the very least. Try your router setup on a exact sample and be very, very picky.
You need to have a very good idea of your end product, what you are shooting for (literally)
There is a lot of hand work; you're going to wear out a couple good rasps.
Have a sample stock to take measurements on, and if your friend wants modifications from that, be sure you know what they are and then add a little.
There is a huge amount of fitting.
Re: Gun stocks
Re: Gun stocks
TomD
Most wooden stocks these days are pretty bad. Back 30 or more years, we had the Weatherby type, stock with the high monty, the pistol grip, the bright finish, etc... These were rightly agreed to be tacky. But rather than improving them, the biz made a grab for the classical english look, that is designed for the use of iron sights and has hopeless ergo for the prevalent scopes.
Stocks are really difficult to get right, like sculpting horses, it is amazing how few people get it right, on the look.
One thing to consider are all the companies that offer semi finished and inleted stocks. These are often pretty reasonable as mere ways of getting wood or laminations, and they are normally fairly complete. Most of them have quirky bad taste features that a woodworker could alter. http://www.boydsgunstocks.com/Articles.asp?ID=253
Re: Gun stocks
Re: Epoxy or pillar bedding.
TomD
Most performance stocks are either epoxy or pillar bedded. If we are talking quality stocks at the art level, as opposed to functional stocks then the wood inletting and everything else, is extremely demanding, It would be probably impossible to pull that off.
Re: Gun stocks
Re: Gun stocks
eliot d
I'm beginning to think this is the "too hard" area. That usually wouldn't scare me off, except that I have no real personal interest. I was only responding to a fellow who I barely know, anyway. Thanks for setting me straight.
Re: Gun stocks
Re: Gun stocks
TomD
Partially inletted are regularly done by non-woodwokers, and it goes up from there.
Re: Gun stocks
Re: Gun stocks
TomD
This is the ground floor:
This is Penthouse:
Of course, there are situations where that red stock would be better.
Re: Gun stocks
Stephen Shepherd
Traditional bedding.
Stephen Shepherd
I had an opportunity to restore an 1804 Committee of Safety musket that had very thin fine linen glued into the barrel channel with hide glue for bedding.
I made my first flintlock[s], rifle and pistol while I was a first year apprentice cabinetmaker, so it can be done by anyone with little experience. Fancier guns do take more talent, experience.
Stephen
Re: Gun stocks
Re: Gun stocks
Brian from Monument
As a gunsmith, having taken the entire curriculum at Trinidad State Junior College school of gunsmithing, it is as some have said difficult to make it really right. It is also not a real strong payer.
The most important course we had relative to this topic was stockmaking 1 and then stockmaking 2.
In stockmaking 1 we took the barreled action we had assembled in the previous semester and made a stock for it. It was a mauser. Mine was a 1908 Argentine Mauser. We started out with a chunk of claro walnut we selected from a local wood stock supplier. It looked more like I had a chunk of floor joist.
The first thing done was to use a mill to make a rough inlet to help inlet the barreled action.
A pair of holes lined on the guard screws. Then route out the area for the action. Then the area for the barrel. These openings were not full size rather rough. All needing hours of fitting.
We used gouges to cut away unnecessary wood. Until we reached a level where about half of the barrel was above the top line of the chunk of wood. By the way the top of the chunk of wood was dead flat. We used files, chisels and rulers. A real woodworker would use a jointer (plane or power tool).
The guard screws were replaced by steel rod threaded to fit the upper metal like the guard screws do.
Then we laid out the view of the stock from the side. Imagine holding a gun where the viewer sees it from across the room from the side. Does it look right? Cut it out on the band saw. Then same thing from the top again across the room. Cut it out on the band saw. Now a lot of that claro walnut is on the floor in a pile.
Then comes rough shaping with a rasp think #49 cabinetmakers rasp. At time a ferriers rasp worked.
Then came final shaping.....
Along the way before this point we replaced a chunk of the foreend with a piece of ebony and made a ebony grip cap. Lots of filing. Remember this was all a college level class meeting 3 times week for 3 hours each time. Plus homework of more filing.
You can buy semi inlet stocks that still require almost all of the above but to lesser degrees. As it is cut on a stock duplicator which vaguely resembles the key duplicator you saw at your local hardware store.
Then comes hours of sanding, more sanding and just when you thought it was safe to begin finishing there was more sanding. Finally finishing.
Needless to say it takes many hours of work. That was my first stock. I have done several since.
The pre inlets are easier but don't allow as much flexibility for things like cast left/cast right etc.
I still think the instructor thinks my stock was too big and clumsy.
A rifle stock takes a touch and a feel to make it right for the OWNER/SHOOTER.
(Instructor and gunsmith be damned.)
Once again it takes many hours.
There are secrets that will help.
Let me know if I can help.
Re: Gun stocks
Re: Gun stocks
eliot d
Thanks for offering help. If you saw my second post, you see, though, that this project is not for me. Actually, I would attempt it, if I had the kind of personal interest that I had when I decided t make a Japanese hand plane; that was worth the effort. But this inquiry was based only on a very casual question from someone I don't know very well who apparently needs a gun stock and knows that I do woodwork.
