New WoodChat!
sharpening "round" plane blade
Howard Pollack
Hi-
I have a nice, heavy, "round" plane (as in hollows and rounds). The blade of this plane has a nick in it. Can someone suggest a way to sharpen/grind it in such a way that the shape of the curve doesn't deviate (too far...) from the shape of the plane body? Thanks for your help- Howard
Re: sharpening "round" plane blade
Robert Tutsky
Robert Tutsky
Hi Howard,
Take thin paper card stock and trace the shape of the iron shape with a pencil then cut the shape out. Using the cut out as a template draw the profile onto the iron with a fine line Sharpie pen shortening its position slightly from the nicked edge. Paying attention to the angle of the original angle (most likely 30 degrees) grind a new profile using files or a grinder to the Sharpie line.
craigd
craigd
Being quite lazy, I rarely remove [little] nicks, just remove burrs caused by whatever caused the nick. If it leaves a track, I just move/rotate the plane a bit and it's gone. It's not like they cause tearout.
TomD
You can scribe the edge with a permanent marker. Roll the tip across a little puddle of layout dye. Or you can find the radial point and draw a radial line right behind the edge. With a nice dark line, you can see the depth of removal. You can also sometimes grab the radial point and pivot it on a rest.
TomD
Those are hoped for things you might have around the house. More correct is layout dye and dividers. My scrub plane has a dimple for dividers right on the blade. I expect to be able to freehand grind a curve, but if I have to remove a lot, it probably pays to lay it out. By the way, you can print a curve out with laser printers and it will make a beautiful transfer for metal layout. The ink line is fine, and really stands out against the steel.
david weaver
If the mouth is reasonably tight, color the face of the iron (the non bevel side) with magic marker or marking fluid, insert it in the plane and let it protrude by the nick amount or a little more. Then scribe it with a carbide or HSS scribe from the sole of the plane.
