New WoodChat!
Plane Iron Heat Treatment Source
Robert Tutsky
Robert Tutsky
Where does one turn to for a source for getting an 01 steel plane iron heat treated. I have heat treated o1 before for carving knives with a torch and was successful but the pieces were small and not very thick. The iron is much larger, thicker and I don't feel a propane or mapp gas torch would supply enough heat to accomplish the job. So where do you believe would be a good reliable source?
Re: Plane Iron Heat Treatment Source
anywhere
Bill Tindall
Even in the remote area I live in there is a place that does heat treating for area machine shops. Ask at a machine shop where they get their stuff done.
And then there are the knife makes. Several in my area have furnaces for simple heat treat like O-1.
And the knife makers have several place where they send stuff to. Someone has assumed Bos heat treating business and they do piece work. Check a knife forum (eg. Bladeforums.com)and they will discuss many places.
R Payne
If you feel comfortable heat treating O1, a forge is very simple to make that will work with a plumbers torch (either propane or MAPP). Search for "one brick forge". Get a soft fire brick (or two) and Bob's your uncle.
ron
TomD
Paul Boss is the preferred knife maker dude.
http://www.bosservicesheattreating.com/15601.html
Not too sure how small he goes.
I agree about the forge. Some folks claim to have forged 12" bowies in ones powered by by propane torches. And two torches are another option, in a forge. I use a Hybrid burned shorty, though the T-Rex is a better overall deal.
I think this is an interesting mini.
http://www.rayrogers.com/miniforge.htm
I generally prefer venturis, but blowers are sure fire, and this one requires zero machining, or rare parts searching.
Patrick Gibbons
I believe Texas Knifemaking Supplies here in Houston will do it by the piece. Google and check their website.
Ron Hock
We can add O1 (only) tools to our batches for $5.00 per piece plus our usual $10 per order to ship it back. We send a batch about every two weeks and it takes about a week to get it back. So, depending on when it arrives, it could take as little as one week or as much as three to get it/them in the mail back to you. Our blades are hardened to Rc62 (so yours will be, too) and, while they are martempered to avoid distortion, be forewarned that there is always a risk of warpage. Sometimes we can fix it (we have our tricks) but not always. Also, there needs to be a hole somewhere in the blade to allow for hanging in the oven. A breaker slot does fine, of course, but a hole at least 3/32" or so is necessary if the blade otherwise has no holes in it. If that's a cosmetic problem, drill the hole in a corner that you can grind off after. Include payment or a CC# with all your contact info. And please be sure there is a legible phone number somewhere in the package.
TomD
I had Ron do me some blades a while back, and you get Ron Hock blades. That is a good price.
Robert Tutsky
Robert Tutsky
After a forge suggestion and further research I made the decision to make a small forge. Realizing that I can be somewhat impatient, sending an iron out would be a problem. Not only that I enjoy chasing after new skills. Thanks guys for your help.
