New WoodChat!
Veritas - Innovation in Tools
How Important Is Frog Adjustment?
Tom Colligan
I've not given any thought to making adjustments to the frog on a Bailey style plane from one planing session to another, either softwoods or hardwoods.
Is this a common practice for you as well? If not, what has been your experience with the frog adjustments and what suggestions or guidelines could you offer? Thanks in advance, Tom.
Re: How Important Is Frog Adjustment?
I don't change it much either
but I'll be interested to hear other folks' experiences.
Me neither
Ron Harper
If I have trouble with a plane that is new to my shop and I think it may be the frog position, i will check it, and adjust it, if needed. Then it stays put.
Re: Like Ron Popeil
david weaver
Set it and forget it. It matters that it's tight and stable, but not that it's terribly easy to reset it all the time.
The only time I moved the frogs intentionally on any of my planes after their first set was when I figured out that it was more useful to have a properly set second iron than it was to have a tight mouth.
craigd
Re: Like Ron Popeil
craigd
+1
I've spent a fair amount of time playing with the mouth adjustment on Stanley [-like] planes (45º), and cap iron placement is way more important. In fact, I'm much more likely to set the frog too close, which causes clogging (as the geometry of the front of the mouth interferes with the cap iron).
I also did a quickie test on a 55º infill and the mouth opening was pretty irrelevant.
Here is a composite photo of five planes that perform about the same, the most open mouth is about 1/8".
