New WoodChat!
Follow up to the Plow and Fillester question
Tony Wilkins
So when the time comes to get the LV Moving fillester -- I know the fillester has the nicker and skew to work cross grain, how well do with the grain? Rephrasing - if I get the fillester is there any need to get a different tool to work with the grain?
Re: Follow up to the Plow and Fillester question
Wiley Horne--So. Calif.
Tony,
A moving filletster will work on long grain, but as with all things woodworking there is a caveat or two. Or three...With the fence attached, you can plane in only one direction, so you will either be with the grain or against the grain. If against the grain, unlikely you will get a finished surface. (Across the grain, direction doesn't matter, the nicker severs the fibers and the blade scoops the shaving up.)
However, the LV skew rabbet can also serve as an unfenced rabbet plane. So if you remove the fence--I suppose you can remove it--the plane can go either way on the board, and you can get with the grain, once you have established a shoulder. Provided the grain lies in one direction the length of the board.
With hardwood, especially figured hardwood, reversing grain is very common. So if you picked a piece of reversing grain hardwood, then you're down to your personal skill in dealing with reversing grain.
All in all, the answer to your question is that the LV skew rabbet gives you both a straight rabbet plane and a moving filletster. So it's very versatile.
Wiley .... wondering if Derek has a review or tutorial on the skew rabbet.
Skewed planes
Derek doesn't seem to have a review up, to my surprise; maybe I missed it.
One concern about skewed planes is that, if you're freehanding it, you have to watch for a tendency for the plane to wander sideways, as the skew pushes it in that direction. Fences, whether mounted to the plane or the work - or the wall of a rabbet, once it's established - limit the plane's movement to one side.
There is this one ..
At the time the Skew Rabbet planes came out there were so many posts on the forums that a review was not necessary. Instead I posted using the plane(s) in a couple of furniture builds, such as this one ..
http://www.inthewoodshop.com/Furniture/Raisingapanel.html
Making do with a small bench and limited work holding (.. times have changed :) ) ...
I hope that helps.
Re: There is this one ..
Mike Holden
And of course, as Derek shows, the Veritas comes in both left and right handed versions. This eliminates the need to remove the fence and use in a direction where the skewed blade would tend to exit the cut.
Mike
archie
For rabbet cuts, perphaps not. But for groves and dados, absolutely that's a great excuse for getting another tool :)
